Results 1 to 16 of 16
Thread: Just getting started
    Hi,
    I became a pool owner recently. With rising temperatures i am worried i wont b able to enjoy swimming for long.
    Please suggest to cool my pool.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Just getting started
    Welcome to TFP! Curious...where are you located? After this harsh winter in much of North America, most everyone is more concerned about warming their pool water.
    To answer your question though, aeration is the best bet to cool your water. This can be done by the use of fountains or a waterfall such as from a spillover spa. Do not bother using ice. You will need prodigious amounts of it (hundreds to thousands of pounds depending on pool water volume) and the effects will be temporary.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    + 1 to what Bo said. What is the temp of your pool ?
    If you could add all your pool and equipment info to your sig that would be great. It'll help us better help you. 😎
    Jeff
    Vette's Avatar
    Jul 2012
    Ohio
    404
    My pool is a block of ice right now, so I wish I could swap places!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Bo knows...
    Essential Links:
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    You could make (or buy) some sort of fountain that connects to a return and sprays into the pool. The evaporation will cool the water, but with a side effect of raising the pH. That is the cheapest and easiest way. Or you could put in solar heating panels and run them at night to cool the water. Or you could put in something like a glacier pool cooler.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Thanks everyone ! Does anyone know hw to make a fountain in pool ? are there any DIY kits ? what is a glacier pool cooler ?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The simplest fountain is to take a length of PVC pipe and drill a number of small holes in it (sort of like a shower head) and install it in place of one of your eyeball return fittings. There are a number of examples that have been posted here over the years, the best seem to be using a T layout of PVC pipe and and 45 degree angle fitting to place the T with the drilled holes at the water line.
    See http://www.troublefreepool.com/threa...untain-project
    or
    http://www.troublefreepool.com/threa...sy-pool-cooler
    for a couple of examples
    The Glacier pool cooler is like a swamp cooler for pool water, therefore it tends to work best in hot dry climates, there are also heat pump systems which will heat or cool pool water and work like an air conditioner
    Can i get this job professionally done ?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you check on ebay for "pvc pool fountains" you can find some semi professional looking options starting at around $20 that screw into the eyeball fitting sockets. Connecting it should be no harder than connecting a garden hose, assuming your pool has standard style screw in eyeball fittings.
    Ike
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Thanks a lot !! m goin to explore this option
    Jan 2013
    Houston, TX
    1,079
    My pool cooler experiment:
    http://www.troublefreepool.com/threa...07-Pool-cooler
    Considering a glacier sometime soon.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    It looks like my Pool wall fittings wouldn't easily come out.
    Is there any Pool Cooler for inground pools which can be mounted on the existing fittings thereby reducing the hassles of removing pool wall (inner) fittings ?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you remove the adjustable "eye" from your wall fitting, are there a pair of grooves in the piece the eye attaches to?
    If there is, you can get or make a tool to remove that piece. Then you should be able to screw the appropriate fountain in it's place.
