Thread: tested cya with water temp of 61
    Aug 2013
    dallas,tx
    79
    Wink tested cya with water temp of 61
    Is my test result accurate at that temperature? Hope so as that means I finally dropped my CYA level
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
    Re: tested cya with water temp of 61
    There is no clear cut off temperature. When the water is colder the white cloudiness takes longer to develop. If you move along too quickly at colder temperatures the sample might not get as cloudy as it will eventually get by the time you take the reading. While if you wait a little extra for the cloudiness to form you will get a correct result.
