Thread: Taylor K-1766 salt test
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    just received my K-1766 and tested my water
    when you add the R0718 silver nitrate do the drops completely disolve or partialy solidify
    i ended up with little lumps in bottom of test vial
    thanks,
    Andrew
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Taylor K-1766 salt test
    It's extremely common to have precipitate in this test. The trick of this one is learning the true end point.
    Essential Links:
