Thread: Pentair Stop leak?
    Pentair Stop leak?
    Has anyone used this or anything like it? I have some leaks in my solar panels and the installer suggested this for fixing them.
    Pentair 48220000 1-Quarts Bottle Stop Leak
    LB
    Sunny Sarasota Fl area
    10K Pool/SPA, Pentair equipment
    IntellifloXF
    Easytouch upgrade Panel
    Intelliclor IC-40
    Techno-Solis Solar Panels
    Re: Pentair Stop leak?
    I don't think that it's a good idea. It would be best to figure out what's leaking and fix it properly.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have used Marliq fix-a-leak for an underground suction side leak with somewhat reasonable results, you can find my message thread on it http://www.troublefreepool.com/threa...uid-Fix-a-Leak I don't know anything about the product you posted. However for something accessible like a solar panel I would tend to look at more direct repair options (plugging, etc.) depending on the style of the panels.
    Ike
    p.s. I see you have techno solis panels which can not be plugged by traditional methods, however I have read some people have had positive results with plastic heat welding leaks on them
