Results 1 to 11 of 11
Thread: algea howlong when pool empty before green algea dead?
    Mar 2012
    spain
    48
    hi
    I had green algea
    pool is empty
    howlong before they are dead?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What type of pool do you have, inground, above ground ?
    I don't know how long algae can survive out of water. Regardless your going to have clean the pool with a water,bleach solution.
    Somebody else may have a better answer for ya.
    If you put all your pool info in your sig, it will help us help you better.
    Jeff
    Mar 2012
    spain
    48
    Re: algea howlong when pool empty before green algea dead?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I remember seeing that pool. Very interesting.
    Can you give a little more detail in what you want to do ?
    Jeff
    Mar 2012
    spain
    48
    hi
    its full with algea currently
    its gonna be empty for cleaning etc
    now howlong would it take when its empty before the algea would be dead
    and what would be the best way to kill the algea inside the tubes? just use bleach?
    here the current condition, while its being emptied
    http://s12.postimg.org/wcglr6rks/20140222_183304.jpg
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can kill the algae using the SLAM method. http://www.troublefreepool.com/conte...tain-shockingl
    Is the pool still full now ? It sounds like you want to drain and clean it, correct ? By the "tubes" I take you mean the plumbing. Like I said before I don't know how long algae can live without water.
    I see your draining it now. Yes you'll have to use bleach - water solution for the plumbing. Are you going to pressure wash the pool bleach/water solution or something of that nature to kill any remaining algae ?
    Jeff
    Mar 2012
    spain
    48
    yes correct I mean the plumbings
    and yes I will be pressure washing the complete pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ok. Yes you'll have to get some bleach/ water solution in the plumbing to kill off any algae in there.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you can spray the surfaces with bleach (liquid Chlorine) after you are done pressure washing and cleaning it will kill most of the Algae.
    Complete the SLAM process upon filling the pool and it will kill any remaining Algae and Algae spores in the whole system.
    Essential Links:
    30,432
    The short answer is, "Never." Algae spores are continuously entering your pool water from the atmosphere as well as any remaining hiding in your pool surfaces. Waiting for the algae to be dead in your pool walls is virtually meaningless.
    Without a constant chlorine residual, algae simple returns to your pool. Chlorine in adequate dosage prevents and kills algae.....draining has little to do with it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed, I just meant for this clean and start up process.
    Essential Links:
