Thread: Jandy SWG issues with 1400 plc
    Feb 2014
    California
    1
    I replaced my first unit which lasted about 5 years, with regularly muriatic cleanings of mineral build ups. I installed the new unit about 18 months ago, and started receiving code 120 errors. Removed the cell, cleaned it thoroughly, reset system, started up and 120 code remains. is there a specific trouble shooting protocol beyond the cleaning and making sure the contacts to the cable are clean? Anyone actually had a cable fail to provide adequate electrical connection. I hate shelling out another $450 for an product that should last more than 18 months..
    thanks for your input. I generally am quite happy with my pool setup with the jandy equipment I have, this one is a little bothersome...
    J
    Jun 2011
    Long Beach, CA
    2,781
    Re: Jandy SWG issues with 1400 plc
    Welcome to TFP John!
    There are lots of previous threads on this error code such as this one, http://www.troublefreepool.com/threa...-codes-120-121. Use the search function and look up aquapure error code 120 and you might find a thread that meets your needs.
    What it comes down to is you need to measure the voltage across the cell to determine what is happening. This error code can lead to a bad board, a dirty cell, or the cell is failing. If you don't find enough information let us know and we can try to help some more.
    Did you replace the cord when you replaced the cell? If you didn't, it might be worth trying. There are tests you can do, but replacing the cord might be easier.
    Support the site
