Results 1 to 10 of 10
Thread: O-ring Lubricant
    Dabby's Avatar
    Aug 2010
    Saginaw, TX
    41
    O-ring Lubricant
    I have a Hayward cartridge filter that is seeping water at the middle rim. I have read several places that state the o-ring needs to be lubricated with a silicone-based lubricant. The manual that came with the filter says not to lubricate the o-ring. I am confused. Should I lubricate it or not?
    24K gal, QuartzScapes plaster, Hayward EcoStar 2 hp variable speed pump, Hayward 525sqft SWIMCLEAR cartridge filter, Hayward Aqua Rite SWG, Polaris 280 pool cleaner with Hayward booster pump, Hayward 1.5 hp Tristar pump for water features, Aqualogic PS-4 controller with wireless desktop remote.
    Re: O-ring Lubricant
    I use the silicone lube.
    Support the site
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    ...and I use the teflon "pool lube". Either will work fine...just don't use a petroleum-based lubricant or it will destroy the o-ring.
    Dabby's Avatar
    Aug 2010
    Saginaw, TX
    41
    I could not find a silicon-based lubricant while I was out today. I have a can of GM Super Lube. Anyone know if this would work? I know it is safe for rubber and plastic.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Faucet lube from HD or Lowe's would be great - in a pinch some KY Jelly would work, too - preferably not one of the 'enhanced' versions..........
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by Melt In The Sun View Post
    I know it has big letters that say petroleum jelly on Vaseline but I've used it on a ton of O rings with no adverse affects , , , but none were for a pool. I'm getting ready to replace the sand and O rings in my filter and would normally just use Vaseline. Does it have an adverse effect on the rubber they use in pool equipment ??
    Solar Blanket, Well Water, Borax Added. 68
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It depends on the type of o-ring material, but petroleum jelly will cause common rubber o-rings to swell. A sign of its use is when you open a valve up and the o-ring jumps out and will not seem to fit back into the grove where it belongs.
    Ike
    Over the very long term (8+ years) petroleum jelly will cause most o-rings to fail sooner than they otherwise would.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I just hate to buy another chemical but I believe and I'd rather do it right. I was even a little sorry to ask but I'm glad I did as going with silicone is likely better for my automotive applications as well.
    Thanks.
