Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: My Outdoor Fireplace build...
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Well I searched all over the internet looking into options into doing a outdoor Fireplace next to my patio/pool. I couldn't find any real direction to get going on it.
    Talked to my landscaper about my vision...$4,800! I just couldn't see spending that (was budgeting half that). So the excessive price talked me into trying to do it myself.
    I found a nice site Backyardflare.com, they will sell you plans to build your own fireplace...all for $35. Seemed like a great place to start. I found a plan the wife and I agreed on and ordered them up. I can honestly say, it is pretty easy to build these things once you have a step by step break down. I actually modified the plans a bit on the fly and it turned out pretty good.
    If your a handy guy this is something you could tackle easily.
    Costs so far:
    -Concrete pad with Rebarb $400
    -Supplies from Lowes $500
    -Firebrick from Brickyard $100
    -Travertine for Caps and accents $250
    -Stucco from Contractor ~$300ish
    Total: ~$1,500...saved $3k!!!!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: My Outdoor Fireplace build...
    So far this is where I am at...This picture is After the mantel is hung an waiting for the liquid nails to dry on the steel rods supporting it.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Very cool. I assume you're doing the brick work yourself. Do you happen to have a pic of what the final product will look like?
    Also, since it's a wood burning fireplace, do you have minimum height requirements for the chimney? I know this has been an issue during our design discussions on our covered patio.
    Keep it up..
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    http://www.backyardflare.com/pima%20ii.html This is the plans for the fireplace. As you can see I did modify it. Made it a bit taller to conpensate for the mantel and took out the ledges.
    Out here there are no building codes for outdoor fireplaces. Some towns have a minimum clearance from the top of the chimney to the nearest part of the house of 10 feet. Mine easily clears that.
    That's a nice looking build.
    Thanks for posting the link for the plans as I am wanting to build one myself.
    Sincerely Vic
    Jan 2011
    Richmond, Texas
    595
    I am really interested in seeing the final product. Please keep posting the pics.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Added some travertine to match the decking...
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Very nice! excellent job. I can relate to the high cost for a pre-cast with a move. I'm impressed and will use this thread for a friends FP build. Thanks for posting.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Quote Originally Posted by NoFear95
    That looks very nice.
    I have ordered a set of plans for the Santa Cruz.
    Once the arctic blast recedes I plan to get started.
    A quick question when you installed the firebrick or refractory brick how did you secure it to the CMU.
    Did you in-bed any fasteners or clips in the CMU or just use mortar between the two bricks?
    Thanks in advance, Vic
    Isaac-1's Avatar
    SW Louisiana
    6,711
    looks great, a real inspiration for all of us
    Ike
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Quote Originally Posted by cudavic
    I used a high temperature adhesive. You can use refactory Mortar...but its about $50 for a 80 pound bag. Since I don't have exposed mortar joints I went the route of the adhesive. So far I tried it out twice with no issues.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Completed the stucco this weekend to match the house...just need to paint it up and I'll post an updated picture. All in with everything I probably have ~$1,600 into the project. This was a project I got qoutes of $4,500-$4,800....wasn't beyond anyone who is handy...an a $3,000 savings made it worth it!
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Very cool...in for final pics.
    Butterfly's Avatar
    South Carolina
    10,045
    Great project and nicely documented!
    Looks fantastic so far and can't wait to see the final pics
    You're done SLAMing when:
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Stucco Completed today...just need paint!!!
    Feb 2013
    Yukon, Oklahoma
    220
    This DIYer thanks you for the motivation and information on doing yours. Now at least I can point to this to the wife and go, see.....somebody else wants to do this stuff too!!
    Great job.
    Bob E.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    I'd post some updated pictures but the file size limits are soooo small, yikes. Onto the outdoor stereo next!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That looks awesome. Nice job !!
    Jeff
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Final Update...Painted an used. Quite a project, but will worth it for the savings!
  20. Back To Top    #20
    Looks great. I think instead of those small lights, I might of used led strip lights under the overhang.
