Results 1 to 16 of 16
Thread: Pool pump will not turn off
    Pool pump runs continuously, replaced grasslin 24hr timer Fm1stuzh but it seems the timer is bring overridden. How to reset or make timer work again?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool pump will not turn off
    Welcome to TFP!
    You are going to have to give us some info on what pump you have and what other kind of controls you have on your pump. Your timer has a manual override switch that needs to be in the middle position for the timer to work.
    It's a lennovator pool and spa control system. LG Base PCB PN: 02-2525-P0. Timer is in middle position to run on the clock dip switches, but even if unplugged still runs unless I trip the breaker switch.
    Wires all seems correct, it is as if the timer is being bypassed or overridden by somehow.
    Timer just stopped working 3 days ago and began running continuously. I figured the timer was bad but after replacing no change.
    Some additional information: timer worked correctly for a short time (few hours) after resetting circuit breaker, then would not turn off again running continuously until the line power was turned off again. Seems as though a relay or something is tripping to bypass / override the timer. Temperature sensor relay perhaps? Nighttime temperatures are now in mid 40's Farenheit.
    22,545
    It could be that the freeze protection is keeping it running. Have you tried warming up the temp sensor to see if it shut down?
    Not sure where is temperature sensor?
    Ok, located temperature sensor in wiring diagram, will try to locate physically tomorrow and warm it up to see if it is causing the problem; can it simply be unplugged also?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Not sure if the schematic you're looking at is the one on the inside of the front panel, but if you need a better copy and more information on features/fiunctions, there's a full manual online at:
    http://www.swimmingpoolsetc.com/pdf/...tor_Manual.pdf
    There's details in the manual on the freeze protection feature that Dave noted, which runs the pump continuously when it senses less than 35F.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    It is definitely related to the temperature sensor. I disconnected the sensor and it ran correctly for a few hours then ran continuously again. Today I reconnected the temperature sensor and it turned off correctly as soon as it was reconnected. But after a few hours again it started running continuously again. It seems to trip either way. I run the pump at night anyways and live in AZ so freezing is no really a concern. Is there a way to remove the temperature feature and use without the temperature sensor?
    What part of AZ? I'm in chandler and mine has been in freeze protect that last 2 or 3 days. I had to reset the main breaker to fix it. Seems as it was stuck in freeze protect even though the oat was 60*
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Could be a sticking relay switch.
    The electronic part of the timer drives a relay which operates the pump.
    When the pump is supposed to be off, according to the timer, but it is seen running, use the plastic handle of a screwdriver to tap the relay casing, observing if this makes the relay switch turn off.
    Another way would be to connect some kind of indicator light (a led in series with a resistor maybe) in parallel with the relay coil, to see what kind of signaling is going to the relay which runs the pump.
    Don´t be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Do you know which relay? K12 far left relay?
    It seems to work fine after circuit breaker stays off for a while and restarted. Then it runs fine according to time clock for about one hour then turns on and off continuously or runs continuously.
    How are the relays attached to the circuit board? Can they be replaced?
    Thanks so much. I am in Chandler, AZ.
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    The relay running the pump is probably the one closest to the pump terminals. To be really sure you have to remove the circuit board, turn it upside down and trace the copper path leading to the pump terminals.
    The relays are soldered, very easy (for someone who knows what he is doing) to replace and relays are very cheap parts anyway, so if you go this way, just replace all of them.
    If you do replace all of them, keep the old ones, they are not all bad and they might be used in an emergency or for testing reasons etc.
    All of the above is valid if the pump relay is in fact sticking, but there are other causes that could result in a malfunction like the one you are having, even a bad (aka "cold") solder joint could cause something like that.
    Anyway, relays are designed to be very cheap, they can last only so much time, and once you see the inside of them, you probably won't believe that we trust this cr@p part to run equipment worth hundreds or thousands times more.
    In fact, for more serious applications, critical relays are placed on bases, so they can be removed / replaced quickly and easily, without soldering anything when they fail, and yes, we know for a fact that given enough time, they will fail.
    Anyone have any experience replacing the temperature sensor? how to remove old one without dropping inside PVC pipe (seems to be glued to PVC pipe with PVC Cement. Is it supposed to be installed that way? I would hate to replace the entire piping if I can drill it out or extract another way.
    Thanks in Advance!
    22,545
    They're normally clamped onto the pipe with some silicone sealant applied under them. They're pretty easy to peel off if they're installed like that. I've never seen one installed using solvent cement. A pic might help.
