Thread: Is this compressor strong enough
    Jul 2013
    Brampton, ON
    24
    Hi guys, could u tell me if my compressor is strong enough to blow the lines? Thanks
    https://www.dropbox.com/s/f1bdyuuglequ3 ... 7%20PM.jpg
    https://www.dropbox.com/s/pao8ik3f2000l ... 5%20PM.jpg
    Inground Pool
    Jacuzzi Laser 225 Sand Filter
    Jacuzzi Pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Is this compressor strong enough
    Technically any air compressor would be strong enough as even though it delivers a small volume of air it does so at a very high psi. So when blowing out your lines they won't violently blow out water like a [high volume] cyclone vac. A compressor would be able to blow a much larger and deeper main drain than a cyclone vac as a cyclone vac maxes out under 10 psi or so. The compressor will just take longer but it will get there eventually.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2013
    Brampton, ON
    24
    Ok perfect. I have a gauge in the compressor that says psi and numbers. What psi should I go up to?
    Inground Pool
    Jacuzzi Pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    you don't have to raise it much, you could keep it as low as 15. Just don't go over 60 as that's a lot of psi just in case. You don't want to stress the pvc.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
