i think the test kit should be modified somewhat:
if its an indoor pool with no sun, no dirty air (filtered air as is in some aquatic centres), a clean pool deck, low or no bather loads, yeah you could keep FC's down to IDEAL recommended levels ( 1.5 to 2 ppm as its depicted on the kits).
The big mistake is ' its physically impossible to do that for an outdoor pool ( that would be my mistake) to keep those levels (FC"S) low like that.
its, as mentioned, pretty much, a feel for what you see the pool door ' outdoors'. if there is alot of wind or dirt or rain, or a lot of sun with not enough CYA then yeah it would become a sudden problem .
the end result is that you would have to increase the FC's to a level that doesnt seem to cause cloudy water ( factoring in of course the CYA levels from the pool calculator).
