Thread: Multi-port valve small leak
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    There is a small leak on the top of the multi-port valve (where the handle is). Is it possible to take this valve apart and clean/lubricate/repair it? Here is a picture of the valve I have.
    Kamil
    28K gal installed 1985, IG Vinyl, Jacuzzi Sand Filter ST-24 (60 GMP) DVK-7 Valve, Jacuzzi Magnum Plus pump
    22,551
    Re: Multi-port valve small leak
    That looks like either a DV-7 or a DVK-7 valve. Does it clamp on or bolt on? The DV-7 clamps on and the DVK-7 bolts on.
    You can find parts for them, but they're getting harder to find.
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    It looks like it's a bolt on. How much are these? If I had to replace it. Can I use different valves with this sand filter or does it have to be the same model?
    Here is a pic of the system. The PO cut the original return line and connected a PVC pipe that runs into the pool on top of the deck. (pipe not shown)
    Kamil
    22,551
    That's a DVK-7. You can buy a repair kit for it for less than $50. Just search for "DVK-7 parts" and you'll find them. You can also buy the complete valve.
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    Thank you for your help.
    Kamil
