Thread: Polaris Pool Cleaner gets stuck
    Chad628's Avatar
    Jul 2013
    San Francisco Bay Area
    99
    Hello All,
    My Polaris pool cleaner very often gets stuck as shown in the attached photo. Has anyone experienced this problem and have a solution?
    Thanks
    Petaluma, CA., 11K gallon IG pool, white plaster, Nautilus FNS 36 sq. ft. DE Filter, Jandy 1.5 HP variable speed E pump, Pentair Booster Pump with Polaris Vac-Sweep 280 pool cleaner, Jandy Laars LX Pool Heater, Remodeled (new plumbing, plaster, tile, coping, variable speed pump) January 2013. 400 gallon Artesian Island Spa (Ozonator/Chlorine), TF-100 test kit, SpeedStir.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Polaris Pool Cleaner gets stuck
    I had adjust the hose floats to keep mine from tangling. I have put two hose floats a little closer to the swivel which keeps them from getting tangled. You also may consider adding another swivel.
    If that doesn't work, you may want to consider replacing the swivel ball bearings. This post has a youtube video on how to replace bearings:
    polaris-280-hose-swivels-t58042.html
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Chad628's Avatar
    Jul 2013
    99
    Thanks kcindc for the information. On your advice I ordered two new swivels from Amazon.com and replaced them in my hose today and the cleaner is working perfectly again!
