Ok, I am new to this site and trying to learn some things, I greatly appreciate all input from you professionals.
I have a 15000 gal cement/ Marcite Inground pool with beach area and spa in beach area with a spill over of half inch. Four foot drop waterfall, hayward automation swg.cartridge filter.
Pinch a penny suggests...tc 2-4. TFP says. Tf100 says.. Tfp swg says.....
Ph. 7.4-7.6
Ta. 80-120
Cal h 250-400
Cya 60-80
Tsd. 300-3000
Salt 270o-3400
I won't list all the levels for the rest but that's 4 suggestions with 4 different level amounts. Some are small differences some are larger differences. I never have used borates and have read that section also and it sounds good and if you all suggest it I will do it.
So I guess my question is what levels should I use for swg? And if you suggest borates which levels should I use for that?
Got my tf kit today that tfp recommended. And played with it a little bit. I think I'll get used to it after a couple runs at it.
Ph. 7.4-7.6
Ta. 80-120
Cal h 250-400
Cya 60-80
Tsd. 300-3000
Salt 270o-3400
