Thread: Date Stamps on Posts
    Jun 2008
    Near Tampa Florida
    17
    I find the date stamps on posts to be confusing. Typically I see something like:
    Posted: Jun Tue 2008, 09:27.
    It seems that instead of showing Tue it should be showing a date.
    Mike
    10K Gal IG Plaster, 1 HP Pentair WhisperFlo Pump, 100 sq ft Pentair Clean & Clear Cartridge Filter, AquaRite SWG, Paramount PCC2000 pop-up cleaner, Rheem/Raypak 266 heater, TF-100 Test Kit, SpeedStir
    Re: Date Stamps on Posts
    This is something you can control yourself!! Go to User Control Panel (upper left, under TFP logo) and then click Board Preferences. You can then choose your time and date format from a dropdown box.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2008
    Near Tampa Florida
    17
    Thanks. After making the adjustment and I can better understand when things were posted.
    It seems strange that the default would have been such a confusing format.
    Mike
    Quote Originally Posted by mikemctx
    Mike
    not everyone has this problem, but there have been one or two others... not sure why.
    Mine has always been day month date year time. Thu Jun 19, 2008 6:10 pm
    Never had to alter it!!
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Clear you cookies and give it a try, otherwise check back tomorrow. This is do to the server change and should correct itself.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
