Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: CYA at 90ppm
    May 2013
    Atlanta, GA
    27
    CYA at 90ppm
    Time to start draining water?
    23,000 gallons
    CL -10+
    TA-110
    PH - 7.2
    CH - 120
    CYA - 90
    The pool is green. Thanks trichlor pucks!
    28' round Doughboy AGP (23,000 gallons) 7.5' deep end
    Aquaview sand filter
    Hayward 1.5HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA at 90ppm
    Yep, if you can. That would make it work much faster. Not that practical otherwise.
    Essential Links:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA at 90ppm
    How did you test for cya? If it is truly that high, like Brushpup said, I too would recommend lowering it before the SLAM process.
    38,524
    Re: CYA at 90ppm
    How did you obtain those test results? Did you not get a kit with the FAS-DPD chlorine test?
    If not, you will need to add it to accurately perform the SLAM process ... http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    I used the TF-100 test. Draining has commenced. Any issues with an above ground pool liner. Pool calculator says drain 53%.
    Hayward 1.5HP pump
    38,524
    Re: CYA at 90ppm
    Why did you not report the FC and CC then and instead just said 10+ Cl?
    Regardless, you should replace 50-60% of the water to lower the CYA. As long as you keep at least a foot of water in the pool everywhere, you should not have any issues with the drain/refill.
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    Sorry ... The FC is 16.5 and the CC is 1.
    Hayward 1.5HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA at 90ppm
    This will be an easy one after the refill.
    Essential Links:
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    Quote Originally Posted by Brushpup
    That's good to hear. I started out with a swamp after opening the pool up months ago. I worked it and it was crystal clear. I made my fatal mistake in not monitoring the CYA and kept adding pucks of triclor a couple of times a week and only monitoring the chlorine and PH
    Live and learn. This was my first year of maintaining a pool.
    Hayward 1.5HP pump
    30,432
    Re: CYA at 90ppm
    All of us started at the same point.....knowing next to nothing about pools.
    I have been doing this for pretty close to seven years and I still learn something new from this forum almost everyday.
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    This site is amazing. I have learned a ton and of course still have a lot to learn. It's funny to hear co-workers that say, " ah just keep the chlorine and PH and you don't have to worry about anything else." These are the folks that I used to think knew a good bit about pools.
    As for the previous statement that I made saying, "thanks trichlor" .... I can't blame the trichlor .... I put it in!!
    Hayward 1.5HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA at 90ppm
    Well, pH and Free Chlorine are extremely important, but there is more to it. Understanding the FC relationship to CYA is critical. Many if not most well seasoned pool owners seldom do.
    Essential Links:
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    Well I drained half of the pool and now I'm filling it. Time to learn the SLAM process!
    Hayward 1.5HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA at 90ppm
    It's kind of fun actually. Not hauling the bleach, but seeing a mess turn into pristine clear water. That is the fun part.
    Essential Links:
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    I agree. When I opened the pool before summer, it was a green swamp with tadpoles to boot. Seeing it go from green to milky ... to clear was fun to watch. I had hardly any CYA and for some reason thought that I could add those pucks occasionally and be ok after pump to waste when vacuuming and rain ....etc. I was wrong. I will stick to the BBB method. Now I can see the relationship of cya and FC, CC. My free chlorine was only half what was needed with that high CYA.
    Hayward 1.5HP pump
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    50% of the water was replaced and here are the numbers:
    PH -7.5
    TA -60
    CYA - 40
    FC - 9
    CC - 0
    CH - 100
    To get shock FC up to 16, I added 16 oz of 63% Cal-hypo.... and swept the pool.
    Does it look like I'm on track?
    Hayward 1.5HP pump
    30,432
    Re: CYA at 90ppm
    Absolutely! Nice work on the CYA.
    Now, keep your FC up close to 16 ppm by testing and then redosing back up.
    May 2013
    Atlanta, GA
    27
    Re: CYA at 90ppm
    We're getting there .....
    Late last night I measured FC and CC:
    FC: 19.5
    CC: .5
    This morning's numbers:
    FC: 16
    CC: 0
    CYA: 40
    PH: 7.5
    CH - 100
    TA: 60
    So I dropped 3.5ppm FC overnight. I'll raise my FC to 20 so hopefully I won't drop below 16 by the end of the day.
    Hayward 1.5HP pump
    38,524
    Re: CYA at 90ppm
    No need to test anything but the FC and CC at this point. Looks like you are getting of top of this
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: CYA at 90ppm
    Yep, good job there. Keep SLAMing and you be there.
    Essential Links:
