Thread: Too high Ta?
    Jul 2013
    Chicago IL
    83
    Too high Ta?
    5300gal AG vinyl pool :: test results
    FC -4.5
    CC -0.5
    PH -7.8
    TA -130
    CYA -30
    Is TA of 130 too high?..can any problems occur just leaving it?
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Too high Ta?
    It's probably okay, but may tend to cause pH rise. If you can deal with the pH, don't worry about the TA.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Too high Ta?
    130 does not seem too high. I would just leave it and let it lower as you deal with the pH. 7.8 is the upper side, so as you bring down the pH it will lower your TA some. Trick is just finding your pools happy spot. I would be more worried about what the pool frog is adding to the pool.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    38,251
    Re: Too high Ta?
    Quote Originally Posted by jcowart
    Totally agree.
    Jul 2013
    Chicago IL
    83
    Re: Too high Ta?
    Pool frog was disconnected a week after opening pool and from reading post on here , never been happier
    38,251
    Re: Too high Ta?
    Add this around it in your signature, or delete it:
    Code:
    Pool Frog
    [s:2sgxjstq]Pool Frog[/s:2sgxjstq]
