Results 1 to 8 of 8
Thread: Jandy gray valve
    Apr 2013
    Florida
    32
    Jandy gray valve
    Which replacement o-rings do I get for this Jandy gray valve?
    15K gal, IG concrete w/ Diamond Brite, Built in Over-Flow Spa, Max-Flo VS Pump, Hayward Star-Clear II C1100 Pool Filter with Aqua EZ 100-sq ft Cartridge Filter Model #: C8610 (Lowes), Great White Auto Pool Cleaner
    Apr 2013
    Florida
    32
    Re: Jandy gray valve
    And how do I properly lubricate both the o-rings & the handle?
    Thanks!
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Here's a link to the Jandy/Zodiac Gray Valve site:
    http://www.zodiacpoolsystems.com/Pro...ay-Valves.aspx
    Once you determine the size and pn of your valve, try asking your questions again.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Apr 2013
    Florida
    32
    Thanks!
    While looking through their online brochure http://viewer.zmags.com/publication/8cf ... f3a979/216, the closest to mine appears to be the Gray Jandy Valve (3-port) part# 1154, 2875 sans the Grease Cup Kit AND my valve's "knob" (#2) looks more like the Grease Cup (#8) not like the "knob" (#2) pictured in the brochure.
    Mike_W's Avatar
    Aug 2011
    142
    Quote Originally Posted by e1836936
    ... the closest to mine appears to be the Gray Jandy Valve (3-port) part# 1154, 2875 sans the Grease Cup Kit
    Well, here's a deal. I found an o-ring kit for the 1154/2875 on Amazon for less than six bucks with free shipping. Heres the link:
    http://www.amazon.com/Jandy-Replacem.../dp/B00BW51MYU
    Lightly lube the o-rings with silicone grease (not silicone sealer ). Don't overdo the grease, it will collect dirt. You can use it on the handle too.
    Mike
    Apr 2013
    Florida
    32
    Great, thanks!
    What about "Magic Lube Teflon Based Lubricant Sealant", I've read about here & elsewhere?
    Mike_W's Avatar
    Aug 2011
    142
    That will work too. I've used it with no issues.
    Mike
    Apr 2013
    Florida
    32
    Great, thanks!
    That's what I have on hand.
