Thread: Clean salt cell
    Clean salt cell
    Hi everyone,
    My salt cell is due for cleaning and I've found a youtube clip on how to remove and clean.
    My question is - what acid do I use to clean it out?
    Thanks in advance.
    T
    13,000 Gal (Est.) 14x28 pool w liner
    Hayward salt system - Aqua rite low salt
    Hayward Pro Series Filter
    Jun 2011
    Long Beach, CA
    2,790
    Re: Clean salt cell
    Use muriatic acid 31.45% strength. You will want to use 1 part acid to 4 parts water, add the acid to the water, not water to the acid. If it is cleaning the cell, there should be some bubbling when this mixture is added to the cell.
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    Re: Clean salt cell
    I used CLR. Worked great.
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
    Re: Clean salt cell
    Which is better - muriatic acid 31.45% or CLR?
    Mar 2013
    Lubbock, texas
    43
    Re: Clean salt cell
    If you have the acid on hand..use it. CLR is a little safer to handle. We have hard water here..very hard...i've cleaned my salt cell twice in 3 months. The clr takes about 5 minutes once you soak the cell....will bubble nicely. Rinse with low pressure garden hose.
    14,364gal AGP
    Jun 2011
    Long Beach, CA
    2,790
    Re: Clean salt cell
    They should both work fine to clean a cell. The acid should be cheaper, but it has to be handle a little more carefully. I use the acid to lower the pH in my pool weekly and I don't have too many concerns handling it.
