Thread: Heatpump size
    Heatpump size
    Hello, looking at a Hayward HP600 heatpump, slightly used unit thats rated for 81000 btu. My pool is 14X32 6 ft deep, located in NE. Will this unit have enough capacity to work ok? Thanks!
    16000 gal, IG, Vinyl, DE,
    Pentair FNS Plus DE, Sta-Rite Max-E- Pro 1 1/2 hp,
    Sta-Rite 333k LP Heater
    2" plumbing, 3 returns, 4 Deck jets, Hayward Colorlogic LED,
    Dec 2009
    Central Massachusetts
    2,690
    Re: Heatpump size
    I'd get the biggest one they make, especially in NE.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    May 2013
    North East Ohio
    959
    Re: Heatpump size
    Quote Originally Posted by necompressor
    I have a similar size pool in NE Ohio - mine is sized at 140K BTU. I would think you should get a slightly larger one...but it really depends what you are trying to do with it, etc.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
