Results 1 to 8 of 8
Thread: Thermostat pool timer
    Jun 2013
    SpringHill FL
    415
    Was wondering if anyone has heard of or made a thermotimer for winter operation.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Re: Thermostat pool timer
    Yep..Intermatic makes one and I have it. Works great! I had a basic timer from Intermatic and was able to order and just change out the internal works.
    Hope that helps. Good Luck!!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Is the idea to turn on the circulation pump when the temperature gets to near freezing?
    Maybe something like this: http://www.heatersplus.com/sst-2.html
    Although, I'd probably want something that gets a little closer to 32*F
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Jun 2013
    SpringHill FL
    415
    Nice! I was mostly just curious about it as it wouldnt work well for me here in NE. But i was reading another thread about not closing a pool in winter and asking if an inch or two of ice build up would be a problem. So i figured there must be a thermotimer and if not I should make one!!! Lol
    Nathan
    Jun 2013
    SpringHill FL
    415
    Foobert yeah sort of like that but was thinking of a digital house thermostat turning the pump on instead of a furnace
    Nathan
    The Intermatic can be adjusted for on/off temp.
    Jun 2013
    SpringHill FL
    415
    I just checked it out Sami. Its a nice unit thanks for the info.
    Nathan
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I have one sitting on my table .. Got to install it before winter .. But its 102 outside !!!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
