Results 1 to 12 of 12
Thread: Air Supply Blower 220 to 120V
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Can anyone tell me if you or how to rewire a Air Supply Silencer Blower from 220V to 120V
    Called their tech support but may have missed them for the evening.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Air Supply Blower 220 to 120V
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Thanks - I was looking to see if you can change the wiring inside a 220V blower to make it run on 120V or if I can just wire as 120V and the motor will burn out sooner as it may be designed to start-up and run on lower amps.
    ColorQ Pro
    TF-100
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I think you just hook up only 1 leg to get 110
    Sean Hannon
    Jun 2013
    SpringHill FL
    415
    Thats what it looks like to me also. The illustration says dont hook 220 to a 110 volt blower but nothing about the other way around. Also the blowers/pumps they sell nowadays are configured to run either or for the most part.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Thanks, will give it try tomorrow and let all know.
    May take the top off and look inside to see how it's wired.
    B
    ColorQ Pro
    TF-100
    22,553
    Do not hook a 220 volt motor to 110 volts or a 110 volt motor to 220 volts. You will ruin the motor.
    According to the linked document they can be wired either way, but it doesn't tell you how to change it.
    There should be a wiring diagram on the side of the motor that shows how to wire it.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Wiring the motor incorrectly, either way, is asking for a $200 puff of smoke.
    MOST motors are not designed to two voltages. It happens, but it's not common.
    -- Guy --
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I just looked at the book, it only shows how to wire the switch. I am guessing the motor is 220 and they are showing only the switch wiring.
    -- Guy --
    Jun 2013
    SpringHill FL
    415
    Quote Originally Posted by techguy
    Agreed . After rereading my post i see how it could be interpreted as thats what i was saying
    Nathan
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    I have a 220V blower that works (spare) and my friends 120V died.
    I will be taking apart the 120v system and checking out the motor. Not a lot of use, so I doubt the brushes are bad, but will look at the contacts for rust etc. Not much to the motors.
    Actually just replaced the motor on my Beam central vac and they are almost identical motors.
    If I cant fix the 120V motor I will most likely just buy a new blower for $123 at the pool supply store and be done.
    If I discover anything interesting I will let all know.
    Thanks
    B
    ColorQ Pro
    TF-100
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Just a note you CAN NOT interchange these spa blower motors. They are either a 220 or 120V motor.
    I will however replace the brushes in the old blower to use for a spare. Brushes on motor were gone on one side. Other side was OK?
    Otherwise its a simple motor replacement for those that prefer to fix things VS just buying new.
    ColorQ Pro
    TF-100
