Thread: Spa Blower
    Spa Blower
    I need to replace my spa blower Polaris 470-02 60hz 240v 1.6 hp. It's attached to my pool. Question: very little dif in price fr 1.5 hp to 2 hp. Should I go with larger and will it make much dif?
    35k IG Gunite, DE 60 SqFt filter, single speed pentair whisperflo WFE 28 2 hp 1.1 sf pump, 7 yr old pool with attach spa, Polaris 380 cleaner w/ booster pump, Jackson, New Jersey
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Spa Blower
    The larger blower will just create more bubbles not stronger jets. Have you ever tried the jets with the blower removed? Some spas don't require it at all while others will not create bubbles without a blower.
    Mark
    Re: Spa Blower
    Yeah. Just not the same without the bubbles. I went ahead and ordered the same blower $200.
