Results 1 to 8 of 8
Thread: Compupool 24
    Guest
    Compupool 24
    Does anyone like dislike this model? I am looking to switch to a swg system. Thanks
    May 2012
    Allentown, PA
    219
    Re: Compupool 24
    I have the Compupool cpsc48. I have only had it installed for about 2 months. It has been producing chlorine nicely. Be aware many of these compupool units don't give the proper water temp or the proper salt reading. My unit often time indicates high salt even though the salt level is correct. Although the LED's go on from time to time it still continues to produce chlorine. Customer service at Compupool is very good, and if you do have a major problem they will replace your unit for you. You might want to consider a bigger unit for you pool so you don't have to run the pool pump so much. I think they are discontinuing the CPSC units and now making something similar, but new.
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Guest
    Re: Compupool 24
    Too small huh? The sales people told me it would be more than enough. Maybe I should return and buy a bigger one.
    22,542
    Re: Compupool 24
    We recommend buying a swg 1½ to 3 times the size of your pool. They are sized for 24 hour per day operation, so theoretically if you buy one exactly the size of your pool, you'll have to run it at 100% 24 hours a day to keep the FC up in the pool.
    Guest
    Re: Compupool 24
    How do I know if I need to switch from 240vac to 120vac?
    22,542
    Re: Compupool 24
    The only way to know that is to know what your current equipment is set up for. Does the pump have a single breaker or a dual breaker?
    Guest
    Re: Compupool 24
    A dual breaker, however the voltmeter is reading 120v when i hold it to the load line. Just kinda confused never dealt with 240v before..
    22,542
    Re: Compupool 24
    To read 240 volts you need to read between the two hots of the breaker. You'll still read 120 between either hot and neutral or ground.
    In that case the swg will need to be set up for 240 volts if you're planning on running the pump off it or running it with the pump.
