Thread: Rebuilt Pool motors - PHX area
    VA2AZ's Avatar
    Mar 2013
    Avondale AZ
    22
    I want to lower my elec usage and replace a 1hp whisperflo (circa 2002) motor with a 1/2frhp two speed whisperflo motor.
    Has anyone had any experience or knowledge about www.azpoolmotors.com?
    Thanks in advance.
    Milt
    IG 8.4k gal, 12x24, pebble sheen, SGS3000 SWG, Triton II TR100HD sand filter, PCC2000 pop up clean, 1hp 2EZ Speed motor with Whisperflo pump for filter, 1hp Century Sq1102 motor w/whisperflo pump for clean, 3.8' pool depth, 2002 build date - Nov 2015 refurb date. Went from 12.2k gal to 8.4k gal and from plaster to pebble sheen w/abalone shell.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Rebuilt Pool motors - PHX area
    Reports are than rebuilt motors tend to last only 1-2 years on average so unless you get a really good deal on one it usually isn't worth it.
    Also, don't forget that when you downsize a motor you also need to downsize the impeller or you will burn up the motor.
    Mark
    VA2AZ's Avatar
    Mar 2013
    Avondale AZ
    22
    Thanks, Mark.
    They kept trying to talk me into a one speed motor, so in the long run, new is the higher road to travel.
    Have a great weekend!
    Milt
