Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: algaecides
    Jul 2012
    Whidbey Island, WA
    397
    algaecides
    Greetings
    from a newbie on Whidbey Island, WA State (not very hot) and pool rarely occupied
    1) if pool is balanced and clear, do I need to use algaecides?
    looked at BioGuard banish (1qt 39.99) and BioGuard inhibit (1qt 29.99)
    both say toxic to fish and other aquatic organisms and other things like remove contaminated clothing and wash before use, etc etc
    2) are these prices fair?
    3) if I have no visible problem, why put this stuff in the water?
    both say for initial application do this and that, for routine maintenance do this and that
    4) if I have no visible problem, can I skip the initial directions and just go to the routine maintenance directions?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Jun 2012
    Howell, NJ
    977
    Re: algaecides
    1) No, if you maintain proper FC for your CYA level.
    2) No idea, never used algecide, never plan to.
    3) Only reason I can see if if you want to treat for metal stains, which require you to lower your FC. Other than that, the only reason is to lighten your wallet.
    4) No need to use any.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Donldson's Avatar
    NW Ohio
    2,906
    Re: algaecides
    Quote Originally Posted by engrav
    Greetings
    Nope
    Technically no since you don't need them.
    See answer to question one
    thank you
    Now all of this is assuming you are keeping your pool properly balanced and chlorinated. What are you using to chlorinate and to test your water?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    Quote Originally Posted by Donldson
    Greetings
    Nope
    thank you
    Thank you.
    Rainbow chlorinator with 3" tabs, tube connected at the top. Taylor test kit K-2005.
    free chlorine is 2-3, sometimes get to 5, then I reduce tabs or turn down the Rainbow
    combined is always zero
    alkalinity is about 80, pH seems stable at about 7.4 with alkalinity 80, if I drive alkalinity to 100 with bicarb pH rises, I then add acid, alkalinity falls and when it reaches about 80 things are stable again (is this CO? outgassing?, pool is 1000 years old so doubt it is new cement)
    Donldson's Avatar
    NW Ohio
    2,906
    Re: algaecides
    Tablets huh? Out of curiosity any idea what your CYA (stabilizer) level is?
    The alkalinity situation you mention is normal, you can let it sit around 80 so it doesn't raise your pH.
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    Thank you, am tired of chasing rising pH and dinking with muriatic acid
    as for CYA, I do test FC and pH and TA often but probably should test CY more often but I have these values
    Sep 2012 80 CY
    May 2013 65 CY
    Donldson's Avatar
    NW Ohio
    2,906
    Re: algaecides
    You check this out: pool-school/chlorine_cya_chart_shock
    You don't need algaecide if you properly chlorinate, but if you are not maintaining the minimum chlorine level for your CYA you can be at risk of algae.
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    thank you
    I have been just letting the stabilizer come from the tabs
    and if between 30 and 100 as per the Taylor web page, saying "is Ok"
    but from the chart would seem CY 65 is high for the FC values
    but with tabs not sure how to alter CY
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    thank you
    will check CY tomorrow and return
    thank you
    Donldson's Avatar
    NW Ohio
    2,906
    Re: algaecides
    I forgot the "should" in there, I promise I wasn't trying to issue you an order!
    have you ever used the pool calculator? calc.html Put in your pool size at the top and enter your current and target levels and it will tell you what to do to make adjustments.
    Tablets will always add chlorine and CYA to your pool, most of us do not use them because of this. The only way to lower CYA is to replace water.
    I know you have been around a little while, have you browsed the pool school recently? A lot of good information on keeping everything in check and making sure that you don't need to add extra (and overpriced) stuff such as algaecide and phosphate remover. It changed the way I cared for my pool, made it easier and much less expensive!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: algaecides
    Realistically, if you keep your CYA between 30 and 50, you will have not major issues keeping your pool clear with bleach/liquid chlorine. When your CYA is over 70, for a liquid chlorinated pool, it can be difficult to resolve algae blooms. If you are using a SWG (salt water generator) the CYA range is higher, but blooms are harder to resolve if not addressed early.
    If your CYA is over 100, plan on changing out enough water to get you back to the 30-50 range.
    -- Guy --
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    should? not a problem
    pool calculator? have been using the one on the Taylor web page, will try the one above
    tabs and CYA? will check CY tomorrow and return on this, maybe time for an adjustment
    been around a while? Not. Bought the place in 8/2011 and pool was green and we could walk on it. Sand was dirty. Pump was busted. Chlorinator leaked. No automation. Etc. But now is clear and we swim in it so have moved to the finer points.
    again will check CY tomorrow and return
    thank you
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    forgot one thing, pool shape is very complex and all records are gone so can only estimate volume, say 25 to 30k
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: algaecides
    If you know it is around 25-30K gallons, just pick a number to feed pool calculator, then when you try using the suggested amounts of chemicals, if you get less than the expected change the pool is larger, and if you get more than the expected change the pool is smaller.
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    Quote Originally Posted by Isaac-1
    good idea
    next time I add something I will use the pool calculator and put in 100% of the recommended amount for a 25k pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: algaecides
    What type of pool do you have, and how is your fill water? (it is best to add your ool info to your signature so everyone can see) also add your general location to your profile, it gives us information about your climate, typical pool season length, etc.
    pool-school/read_before_you_post
    Ike
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    Ike
    thank you, I think done so should appear below this
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: algaecides
    Ok, well if you have a plaster pool I would suggest using CH level adjustment for your size estimation (assuming you don't have very hard fill water) since CH can only be lowered by water replacement, and it usually takes a good bit of hardness increaser to make a small change in pool levels
    Jul 2012
    Whidbey Island, WA
    397
    Re: algaecides
    I guess have wandered off algaecide topic which was answered. Several recommended not routinely. But you all solved that and I now have stuff in the sig so progress.
    Tomorrow will get the whole battery on pool and fill water and move to another section.
    Thank you.
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: algaecides
    For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm. So if you have 2 ppm FC per day chlorine usage, then the CYA will rise by 36 ppm per month if you have no water dilution. So when using Trichlor, you need to watch your CYA level and raise your FC proportionately to prevent algae growth and eventually dilute the water to lower the CYA level as needed. Or you can spend more by using algaecides to prevent algae growth when the FC/CYA ratio gets too low. Since you apparently want to avoid having to add acid, you could do a hybrid of using some Trichlor with some separate dosing in the pool of chlorinating liquid or bleach. That should keep the pH stable and have a lower rate of CYA increase.
