Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: new to the site and new pool owner w/ pics and test results
    Jul 2013
    Tucker Ga.
    13
    Hi,
    My name is Tyler and I've just acquired a new home that has a pool and I'm certain that you all know the rest. I tried talking with the teenage employees at the local pool supply store and haven't really gotten much out of it. As a result, I've decided to buy a complete test kit and want to learn as much as possible to make this a healthy experience. I've updated my profile and signature the best that I can and with that being said this is what I've got.
    Results from 11:10 am test:
    FC: 0
    CC: 0
    pH: 4
    TA: 180 ppm
    CH: 180 ppm
    CYA: 60 ppm
    It was extremely overcast but no rain and I decided to shock per the neighbors instruction with 4 bags of Shock. After 4 hours I re-tested and this is what I've got.
    Results from 3:22 am test:
    FC: 5
    CC: 2
    pH: 7.4
    TA: 180 ppm
    CH: 150 ppm
    CYA: 70 ppm
    We've had an algae bloom and would love to get in control of this. I've included pics of the 10 day forecast and current pictures of the pool. Any assistance would be greatly appreciated and if there is any way that I could be of any assistance please ask.
    What chemicals I do have available are:
    One bottle of Algae Control 32.oz
    2 more bags of shock
    a 5 gallon bucket of Chlorine tablets
    8 lbs. of Hadness plus
    1 lb. dry acid
    2/3 bottle Phos-Free
    2/3 bottle of Ultra Brite
    http://btbradberry.tumblr.com/post/55448243875 - link to all pictures and 10 day forecast
    thanks in advance
    21k gal 18'x36', IG Vinyl, Hayward Pro Series High Rate Sand Filter Model #S244T, Emerson 1081 Pool Motor 1.0 HP Model #K63CXE3D-4791, Vinyl liner and sand in filter replaced 1 year ago, Polaris Pool Cleaner
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: new to the site and new pool owner w/ pics and test resu
    You need to SLAM your pool
    I would only focus on your FC (chlorine) levels. Your CYA is high so you will need to raise your FC levels to a higher shock level to kill the algae and oxidize the CC. Read PoolSchool! understand the CYA/Chlorine relationship and focus on your FC
    Ignore the other readings until your CC is near zero and your water is clear.
    -- Guy --
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    My first thought is "where'd you get those test results??" as they're very suspect. The pH level of 4 is accurate it is very bad. I'd deal with that first then move on to the rest. And CYA, while a subjective test reading, doesn't generally change like that.
    Have you read the Pool School articles found up in the top right hand corner of your screen? That will give you a start as well as tell you how to order a good test kit which allows you to test *accurately* as well as consistently. I prefer the TF-100 myself. You need to be in control of your testing and not rely on the pool store or strips as both are notoriously inaccurate. Don't balk at the price-you'll save it tenfold once you see how *few* chemicals you'll be using and once you stay OUT of that pool store!!
    Have you estimated your pool's volume of water? You'll need to do that also so you can plug the number into the Pool Calculator feature which guides you as to how much bleach, borax, MA or what-ever your pool requires to fix what ails it.
    All those features can be found under "Pool School"
    addendum- just reread and saw that the pH came up 7.4 in second test. Ignore my advice to treat it (as if it were really 4) if you're sure that 7.4 is more accurate.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Oh.. i would NOT use any of the chemicals you have. use bleach or liquid chlorine to kill the algae.
    gotta run!
    -- Guy --
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Hang on to the dry acid, hardness plus, and shelve/pitch the rest............BUT......... keep the tabs handy for vacation and out of town usage. Bleach is your friend. Welcome to TFP.
    Jul 2013
    Tucker Ga.
    13
    after looking at the Chlorine/CYA Chart in Pool School I'm left with a few questions. With my CYA level at 70 ppm I want no lower than a FC of 5 and want to try and maintain a FC of 8? What exactly is a Shock FC of 28? Do i set the NOW FC in pool calculator to 5 and use the SHOCK FC of 28 as the goal or am I way off? A little direction could be greatly used.
    Thanks
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes. Now is 5 and your goal is 28. Hit calculate and it will tell you how much bleach to use. Don't forget to enter the percent of bleach your using.
    5-8. Is your maintaince levels
    28 is your shock level for SLAMMING
    Jeff
    Jul 2013
    Tucker Ga.
    13
    Am I understanding correctly when it says i need to bring to SHOCK FC 2x a day if not more until water is clear?
    Casey's Avatar
    SW PA
    10,448
    That is correct.
    SLAM the pool = Shock Level And Maintain.
    Jun 2012
    Howell, NJ
    977
    You test and bring it up to shock level preferably every hour. If that is not possible, you do it as often as you can.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jul 2013
    Tucker Ga.
    13
    once calculated it's telling me that i need to add 5.45 bottles of bleach to get to the 28 FC, and your saying thats 5.45 bottles every hour or as often as possible with a minimum of 2x a day? are there any specific instructions for adding the liquid bleach or am i just pouring directly into the pool?
    Thanks for everyone's input, you all are making this a much more pleasant experience.
    30,422
    Nope. Have you read the SLAM article in Pool School?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes pour it in front of the return with pump running slowly.
    You won't have add that much every time if you test it often When it drops below 28 then bring it back up . The longer you maintain the shock level of 28 the faster the slam process will go
    Test as often as you can and maintain 28 ppm.
    Jeff
    Jul 2013
    Tucker Ga.
    13
    my test kit which i thought was complete ended up not including the FAS/DPD Chlorine Test. Im going to test again shortly using the test I do have and then I will calculate to get to SHOCK FC this evening, tomorrow i will buy the test which will allow me to measure ppm that high so that I can maintain shock level.
    Thanks
    Jun 2012
    Howell, NJ
    977
    What test kit do you currently have? If it is a reliable one, you can buy the FAS-DPD test separately.
    John
    Jul 2013
    Tucker Ga.
    13
    I appreciate the heads up, the test kit i bought is pretty solid so i think i will look into just buying the test kit individually.
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    As they said above..Do not worry..stay patient...Keep the FC levels up to shock till...Water is crystal clear, The over-nite reading for FC does not drop more than 1.0 (I go to .05 drop over nite) and the CC is 0.5 or less. Brush / Vac.. Brush and more Vac. And don't back wash too much.. Only when the water coming out of the jets (returns) has markedly less pressure ( 8-10 PSI over start level on gauge) and BTW. adding DE helped a lot in my case. Oh turning one of the returns to where it pointed down in the deep end helped too. This is what I what told to do so just passing it on because it worked flawlessly for me ! With best regards, vsat88.
    Vinyl liner in ground. Pool volume 27,000 Gal. Sand filter. Pump runs 365 days a year 24/7 (Hayward pro series model S220T 1 HP. motor). Taylor K 2006 test kit. I use the BBB way found here at TFP. The only thing I buy from the pool store is CYA.
    Jul 2013
    Tucker Ga.
    13
    Thank you for your post and words of wisdom , got the new test kit today and updated FC level was 17.5 and CC is down to 1. Ive been keeping all debris out of the water and scrubbing once a day with the vacuum running at all times. Ibe just re-shocked to bring back up to SHOCK FC, and ill re-test in a while.
    vsat88's Avatar
    Apr 2013
    Phenix City, AL.
    62
    You are on the way to a sparkling clean pool!
  20. Back To Top    #20
    Jul 2013
    Tucker Ga.
    13
    So today I've retested and the FC was 15 so once again I've brought it back up and from what I can tell my CC is down to 0. I am however curious about what I'm supposed to do once the water is crystal clear and passes the overnight test, and will the bleach take care of the cloudiness as well or will I have to add something else for that? Whats the next step I should take in order to make it swimmable?
    By the way, I know I'm bombarding you all with questions but I don't want you all to think it's unappreciated. I am truly thankful for everything you have vested into answering all of my questions, thanks.
