Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Pentair vs Hayward filters
    Jul 2013
    NJ Northern Bergen County
    26
    I need to replace my DE filter and I am not sure which brand to go with. I have a 21' x40', 35,000 gallon pool. My Hayward 1 hp motor just crapped out on me too. I haven 2 hp loner right now. Thoughts?
    Doug - Northern Bergen County New Jersey
    21' x 40' in ground pool, 35,000 gallons, (8' to 3' deep), vinyl liner, Aquabot T4
    2 returns, 2 skimmers, 1 bottom drain, 2" piping around equipment - reduces to 1 1/2" to pool
    Pump ( need new one - using a borrowed 2 hp now), Filter - Pentair Quad 80
    SWG Autopilot CR 52, Heater - Raypack Model R 406A BTU 399,000 gas
    38,547
    Re: Pentair vs Hayward filters
    Welcome to TFP!!!
    I don't think the brand really matters, but you sure want to make sure you get the right size. You have a big pool and we would generally recommend at least a 98 sqft DE filter ... which is on the top of the residential size.
    There is the Pentair Quad DE 100 and I am not sure Hayward goes over 72 sqft on their DE filters.
    Alternatively you could go with a 34" sand filter or a 518 sqft cartridge filter.
    But, I do want to point out that if you have a low debris load or a short season, then you can get by with smaller than these recommendations.
    I know Pentair extends the warranty to 3 years if you buy 3 pieces of equipment at the same time ... not sure if you already bought a pump or if you want to add a SWG or something.
    Jun 2013
    SpringHill FL
    415
    Ive had no problems with my hayward filter and from what ive seen pentair filters are pretty much the same quality
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    26
    Thanks for the quick reply. I believe my existing filter is 60 sq ft. It's so old that the metal plate with all the info on it is unreadable. It is about 29" high and 18" in diameter, stainless tank. Hole just popped in tank and debris is getting to salt water generator filter screen, resulting in my salt water generator always turning off. I think the filter it is undersized and I think the 1 hp motor that just failed on me (looks like bearings are shot, it was streaming loud and froze up) was too small. 2" piping and about 50' to closest skimmer basket.
    38,547
    All 1 hp are not created equal. Likely it is plenty of pump, unless you feel you do not have enough flow for something (spa, waterfall etc)
    Jul 2013
    26
    Re: Pentair Quad Filter-Are You Happy With It?
    I have a stainless steel DE filter 29" x 18" diameter that is shot (hole in tank and holes in screens). Looking at the Pentair Quad 80. My 1 hp pump is shot too. I'm making ends meet with a borrowed 2hp pump and the limping filter. Limited budget but will stretch it for better system. Thoughts on the quad and proper size of pump?
    Jul 2013
    26
    Bought a Pentair Quad 80 with multi port valve. PVC is drying now and overnight. I can see where I can improve on my plumbing of the filter and pump. Waiting until I get a new pump. Borrowing my buddies 2 hp pump for the rest of the season. What type size pump should I get?? I put 2" piping from pump to filter to heater. Looks like it gets smaller going back to pool.
    38,547
    With no special water flow needs, a small 1HP 2-speed would be my recommendation ... maybe the Superflo 1HP 2-speed like I have.
    Jul 2013
    26
    Thanks. I'm looking forward to firing up this filter. Pool is green and I have a party at the house Sunday.
    38,547
    If the pool is green, you need to follow the SLAM Process. [slam:1k8uyz9g][/slam:1k8uyz9g].
    That is not going to be complete by Sunday, so don't get your hopes up
    Jul 2013
    26
    Filter is running well. Shocked pool. On my way to get test kit. Wife is going to be REAL upset with me come Sunday morning if pool is not clear. Fingers crossed!!!
    38,547
    It is highly unlikely that you will find one of the recommended test kits locally unless you have a commercial supply house. The key is the FAS-DPD, most will not know what that is.
    The pool did not get to its state in less than a week, so unlikely to get clear in a few days. Plus you may not have the required tool by then.
    Jul 2013
    26
    You hit the nail on the head. Can't find the test kit! Just had water tested at local place. FAC .5 ( prior to first shock) TAC .5 pH 7.8 TA 110 CYA 40 Calcium hardness 210 Salt 2800 Phosphates 300
    I'm trying to figure out calculator and get yard in shape. Calculator says add muriatic acid and calcium chloride. HELP!
    The important thing your test shows is that you don't have enough chlorine in there.
    Adding muriatic acid to bring the PH down to around 7.5 is a good idea.
    You don't need any more calcium because you have a vinyl liner.
    38,547
    All you want to do at this point is lower the pH to the lower 7s and maintain the FC at shock level as described in the slam process.
    Jul 2013
    26
    Thank you for the reply. Speaking to pool counter people is very frustrating, cookie cutter responses. They are doing their job, but frustrating. I'm on the learning curve here. I like this stuff.
    Jul 2013
    26
    Not sure if luck is turning my way, but my next door neighbor just bought the last DPD test kit around yesterday. Better than nothing!!!
    38,547
    Quote Originally Posted by Dun vegan
    Well, not really. the DPD test is NOT, repeat, NOT the same as the recommended FAS-DPD test.
    The DPD is limited to 5ppm by matching shades of pink ... and as an added bonus, if your FC is high, the pink gets bleached out so you may think you have no chlorine, but infact it is high.
    Jul 2013
    26
    Understood about test kit. I guess I'll make another trip to store to test water. Already cleaned filter as it jumped 10 psi in just three hours. Piece of cake cleaning it. Ph lowered. Pool is looking 100% better. Test and shock again.
  20. Back To Top    #20
    Jul 2013
    26
    Jason- exactly as you said. Used my neighbor's test kit and it showed NO chlorine. It didn't make any sense because I have shocked it three times so far. Used a test strip and it showed the FCC 5+. PH is low now 7.0 or so. I'm chasing the pH, so I am getting the water checked again. I need to grab a Proper pool test kit ASAP, but no time this weekend. Thanks for all your help! This Pentair Quad 80 is kicking butt. I am betting clear pool water tomorrow!!!
