Results 1 to 7 of 7
Thread: Reader now member
    Reader now member
    Hi all,
    I have been reading the form just registered today. Great site, great info. Appreciate it!
    I am in Southern Arizona, I have a small intex pool, will be upgrading the size next year, bought the sand filter this year.
    I have been doing this myself, middle aged woman, with a handicapped daughter, thinking I will hire someone for the ground prep next year.
    I have a leak I cannot locate, so, am going to search the forum for help.
    Index 18 x 48 easy set pool. Hayward sand filter 1/2 hp. Keepin it simple!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Reader now member
    Welcome to tfp, GoldieAZ
    Since you pool sounds like it is relatively small, it may be easiest to just let the pool leak down to where it stops (accounting for your high evaporation rate) and look for the leak at that level. See: http://www.troublefreepool.com/pool-...leak_detection
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    38,251
    Welcome to TFP!
    Thank you for the welcome!
    Yes it is a small pool, Intex Ultra Frame 12' x 36"
    Bought it last year, tried to lift it and do a better job of leveling this year...that is when the leak started.
    The leak, I believe, is in the seam.
    I just ordered a new liner, this really is the perfect size for us.
    I am so glad I found mcoonan (Mike) ground prep info:
    leveling-the-ground-for-intex-ultra-frame-pool-t21143.html
    I have found the foam insulation at Lowes for about half the price as Home Depot.
    I will also buy the 10 x 2 x 6 board and level.
    The thought of doing this ONE MORE TIME (bytes), but doing it RIGHT so it lasts for years is very appealing!
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome aboard GoldieAZ!
