Results 1 to 17 of 17
Thread: cloudy after borate
    cloudy after borate
    I did the borate and all my numbers a nearly perfect yet, my pool is cloudy and wont clear up. Combined chlorine is next to nothing, ph 7.6, ta 100 borate is at 30 cya is 60, fC is 5. Any thoughts?
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy after borate
    Quote Originally Posted by Dier74
    What are the test results for:
    FC
    CC
    CH
    You're done SLAMing when:
    FC 5, CC 0.1, CH 80 (vinyl lined)
    SWG chlorine
    Massachusetts
    Nothing about adding borates should have caused the water to get cloudy.
    The only thing I notice is that your FC level is on the low side. FC of 5 is acceptable, but you never want it any lower than that. Given that the water is cloudy, it would be best if you raised the FC level towards the high end of the range for the moment, say 9 or 10.
    Forgot to mention it is a swg pool. Manufacturer states 1 to 3 ppm of Fc.
    SWG chlorine
    Massachusetts
    I will do that. Will post results tomorrow.
    SWG chlorine
    Massachusetts
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Your CYA level is 60. The appropriate chlorine level is dependent on that. That's why JasonLion suggested those levels. 1-3 is just not high enough. 5 is the minimum as he stated (for your CYA level).
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    That's right. I completely forgot that. Thank you.
    SWG chlorine
    Massachusetts
    Jul 2011
    844
    Please post back in and let us know if you think the borates have much of an effect. There are differing opinions. I for one believe the effect is dramatic.
    Bestway SWG
    May 2009
    Trenton NJ
    497
    I don't mean to hi- jack this thread but my borates are 50 nd the water looks great but we didn't notice a big difference. I guess because we been doing the BBB method a few yrs now and the water has always looked crystal clear. I do think it feels better,to the skin.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Jul 2011
    844
    This year I have raised my borates incrementally. Stage 2 now (I'm at about 35 ppm). Each increase has given me more shimmer and now my ph is locked at 7.5 (i know that's dependent other factors as well).
    Bestway SWG
    Ok. Numbers are perfect but still hazy. No shine.
    SWG chlorine
    Massachusetts
    Well I read on some other sites that calcium harness doesn't effect vinyl pools(which is the same opinion here) however , it does effect overall chemistry of the water. I increased my ch from 80 to 150 and the next day it was clear and shiny again.
    SWG chlorine
    Massachusetts
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by GreatCanadian
    GC
    For a SWG pool, the FC can be lower. FC of 3 would not be a problem with CYA of 60 and active SWG.
    CH isn't required, but it will not hurt anything as long as it does not get too high.
    That's what I figured. Swg manufacturers state cya 60 to 80 and Fc 1 to 3. As far as the ch I don't know if it is a coincidence or not but it is the only thing that seem to clear up my pool. Been fighting it for a week.
    SWG chlorine
    Massachusetts
    Aug 2010
    Dallas, TX
    4,052
    Well, I would not go below 3 for CYA of 60. At 70, I keep mine around 5.
