Results 1 to 7 of 7
Thread: Pentair IC40
    Jul 2011
    North East
    135
    Pentair IC40
    Thinking about converting to salt with the Pentair IC40. Worth it? Is the install fairly straight forward? Amazon has it for 510...is there anything else needed for it?
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    38,237
    Re: Pentair IC40
    Hmmm ... I see the page you are looking at and I am not clear if that comes with the required power center or if that is just for the cell.
    Realize that without a controller ... you can only adjust the output in multiples of 20% ... so any fine tuning must be done with pump run time.
    EDIT: I am pretty sure that $510 is only the cell and you would also need the $322 power center.
    Dec 2011
    Lake Havasu City, AZ
    48
    Re: Pentair IC40
    My opinion? From a homeowner, you can have my salt pool. I've been thinking of going back to chlorine floaters and save me the grief and money. I've already replaced one IC40 and now another is flashing "low life".
    Our water conditions isn't helping. The calcium deposits that they leave behind doesn't help. I've spoke with numerous pool businesses out here and not one would make theirs a salt pool.
    Throw a bag of salt in your pool if that's the feeling you want.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    411
    Re: Pentair IC40
    I am a fan of the Pentair IC40 system.
    Have been running for 3 years at my pool with no problem, actually perfect, plus have installed at four other pools.
    Just like any pool or system your water needs to be in balance.
    The system does require the Cell and Power Center. More like $750 is the lowest price on ebay.
    At my wholesale pool supply warehouse they sell for $1020 cost.
    Then you need salt. test strips to test your water before you begin to add salt, and more CYA. Maybe $100 in stuff.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Oct 2010
    Pensacola, FL
    67
    Re: Pentair IC40
    I've had the IC-40 for five years and have had to replace the $500 cell twice, despite my constant water testing and cleaning the cell as directed.
    I've turned it off and went to the BBB method and now use chlorine bleach. Every once in awhile I'll turn the SWG back on, say if I'm going out of town. I won't buy another cell. You can still add salt (and borates) to make the water feel better. I still keep my salt levels up and the borates are a nice addition.
    Good luck and Happy 4th of July!
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    Mar 2007
    Murrieta, CA
    215
    Re: Pentair IC40
    You won't save any money by going with any SWG. What you are doing is buying the convenience of not having to manually add chlorine, whether it is liquid or tablets. A salt pool also tends to be more stable because the chlorine is generated around the clock, and this definitely makes maintenance easier.
    I have also had to replace my IC40 cell twice. First time was under warranty. The replacement lasted a little over a year so I gave up and went to tablets for two years. Just recently, I bought a new cell and I'm enjoying the convenience again.
    Just figure that it will cost you ~500 bucks every 2-3 years. If that bothers you, then don't do it. Tablets are a decent alternative, as is liquid chlorine. They just require a little more work.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Jul 2011
    North East
    135
    Re: Pentair IC40
    Yeah i realize there would be no savings and I'm even ok if it costs slightly more than likely. I'd be doing it for the convenience but i dont want to be replacing cells all the time bc of crappy equipment. So that's my dilemma
