Results 1 to 12 of 12
Thread: CYA has been consistently low
    Hi I've been adding CYA (up to 5lbs now) and still can't seem to get it to register even at the 20 level. I'm using solid CYA in a sock in the skimmer. I put this in over a week ago...still nothing. Any other ideas?
    Laura
    Baltimore MD
    IG pool 25,000 gallons
    Cartridge filter
    Plaster pool
    Casey's Avatar
    SW PA
    10,423
    Re: CYA has been consistently low
    How big is your pool? Can you update your signature and location please. It would help us out a lot! Thanks!
    38,251
    Please add your pool details and location as described HERE to your signature as it will help us help you.
    We would need to know the pool size to even start to offer ideas.
    Where did you buy the CYA? What is the strength listed on the bottle?
    Casey's Avatar
    SW PA
    10,423
    Have you guys been getting a lot of rain? That could be why you aren't seeing an increase.
    Thank you I updated my signature with the requested info. I have the TF 100 test kit. Following are current readings
    FC: 7 ppm
    CC: 5
    Ph: 7.8
    CH: 420
    CYA: below 20
    Alk: 120
    Laura
    Baltimore MD
    Cartridge filter
    Plaster pool
    CYA strength 96%. Yes we have been getting a lot of rain (thunderstorms).
    Laura
    Baltimore MD
    Cartridge filter
    Plaster pool
    Casey's Avatar
    SW PA
    10,423
    I think that that is your problem especially if you have been draining the excess off the pool.
    38,251
    In a 25k pool, 5 pounds would have only added 24ppm of CYA ... plus given the rain ... I am not too surprised you are reading less than 20ppm.
    Add another 2-3 pounds to get you up around 30ppm at least.
    Casey's Avatar
    SW PA
    10,423
    Be prepared to lose some of that because the rain isn't suppose to let up for another week!
    It's HORRIBLE!!! (That's my rant of the day!)
    Thank u will give that a try
    Laura
    Baltimore MD
    Cartridge filter
    Plaster pool
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Would it be a good idea to aim for a 40CYA to allow for some rain dilution?
    -- Guy --
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by techguy
    Wouldn't hurt.
    Also, just to be sure. One's CYA can also start disappearing if you have a leak. Folks who use autofills and are noticing a trending downward in their CYA can also suspect a leak. The only way to lose CYA aside from a loss over the winter in a closed pool is for it to be splashed out or emptied from the pool either through a leak or down the drain.
