Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Am I Being "Pool Stored"? Using copper to kill algae
    Jun 2013
    Broken Arrow, Ok
    19
    I'm new to the site and definitely not a pro when it comes to pool upkeep. We've been fighting algae for a while now. We just let our pool guy go after the algae just keeps getting worse and worse and the bill higher and higher. I've ordered one of the recommended test kits T100 maybe, but until then I'm having to rely on the pool store. They have recommended adding copper to get rid of the algae after yellow out did not work. (We can't get our PH high enough) Is this ever a good idea????
    Gunnite pool
    28,000 gallons
    Today's test results.
    TC 0.9
    FC 0.4
    PH 7.0
    TA 130
    Stabilizer 68
    We've shocked it every day the past few days and it's not holding any chlorine. Any help is appreciated!!!
    12,000 gallon SWG - IG Medium grey plaster - Water Sheets, Spillover Spa and 28ft x 4 ft tanning ledge
    Hayward High Rate Sand Filter - ProSeries - 2 pumps - 1 variable speed, 1 two speed
    Hayward Heater - Hayward Pro Logic Automated Digital System with wireless remote
    Pool build June 18, 2016 - TF-100 Test Kit with Speedstir - Hayward SharkVac
    22,538
    Re: Am I Being "Pool Stored"? Using copper to kill algae
    Welcome to TFP.
    Adding copper isn't a good idea. You need to perform the shock process correctly to get rid of the algae. To do that you need a good test kit. Luckily you have one on the way. Just try to maintain until the kit gets there and while you're waiting, read through Pool School especially the part about properly shocking your pool.
    38,235
    Welcome to TFP!!!
    What the pool store calls "shocking" and what we currently call the Shocking Your Pool PROCESS are very different things.
    Keep reading while you wait for the kit:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Good on you for ordering the fave kit, TF100
    You need to follow the Shock Process in Pool School. pool-school/shocking_your_pool
    If you have been using a stabilized source for shocking/chlorinating, your CYA # is probably even higher by now.
    I suggest you drain/refill enough to get the CYA to about 50. Then, first correct the pH to low 7's, and then start the Shock Process. You will be using bleach/liquid chlorine for this process.
    Your pH was most likely being lowered by an acidic source, like trichlor
    btw, copper can cause almost-impossible-to-remove stains and is what turns hair green .
    ETA: goodness, you guys are so fast! sorry for any duplicate info
    You're done SLAMing when:
    Jun 2013
    Broken Arrow, Ok
    19
    Wow! Thanks for all the fast replies! I didn't have a good feeling about adding copper so I'm glad I asked.
    We actually just drained our pool to half depth and refilled it. This was advised by our now gone pool guy. He added the conditioner which I think has raised the level too high now. So in saying all that we'd like to not drain the pool anymore unless absolutely necessary. Will it hurt things to leave it as is and see what happens?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    We will know more when we get trusted CYA results from your TF-100 kit, if it really is around 68, this is high enough to be a concern in a manually chlorinated pool, but possibly manageable if water replacement is not an option (you live in an area with water rationing, etc.)
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Welcome to TFP! Listen to these guys and you will have a sparkling pool in no time and save a ton of money in the process. I have been a member since I built my pool last year and I have spent less than $160 in nine months. I have never had to perform the shock process. I read this site every single day and I have learned a lot! I actually have it set as my homepage on my Ipad and computer. If they gave an award for being logged on the most, I would probably win! Good luck and welcome.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Casey's Avatar
    SW PA
    10,418
    POOL SCHOOL!!! It's where it's at!
    Read up before your test kit gets here and you will be prepared and do what your pool boy couldn't!
    Jun 2013
    Broken Arrow, Ok
    19
    Ok here's my next question. My test kit won't be here for a week. What should I do in the meantime? Should I do the shock process but take the water to pool store for testing?
    38,235
    Must not have ordered from Dave
    Do you have the yellow OTO test? You can dilute and get a rough idea of the high FClevel required. That would be better than going to the store.
    Jun 2013
    Broken Arrow, Ok
    19
    I do have the yellow OTO test. How do I go about diluting it? Any tips? Thanks for your help.
    Jun 2013
    Broken Arrow, Ok
    19
    Another question: When I enter my numbers into the pool calculator it tells me I need to add 9 jugs of 6% bleach to raise my pool to shock level. Is this what I'm adding every hour as stated in the shocking section? Holy Cow, that's a lot of bleach and money.
    38,235
    You always test and then reuse the calculator to see how much more to add to get back up to shock level.
    Use one of the graduated cylinders to measure the water ratios.
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Quote Originally Posted by jmcologgi
    ...and yet people spend a fortune and toss in to their pools mass quantities of inappropriate chemicals that the pool store recommends -go figure?
    Bleach is cheap in the sense that you're buying an easily obtained product that does one thing exceedingly well and yet doesn't cause or introduce other problems, unlike what the pool stores sell which do!
    Mar 2007
    San Rafael, CA USA
    12,082
    That isn't what you add every hour. It's what you add to raise the FC to the shock target level. How much you add after that depends on how much algae you have. If you had no algae, then you might lose half the FC to sunlight so figure that's a daily minimum, but with algae it will be more. You test more frequently at first (yes every hour or so if you can and if the FC is dropping that fast) and you add more chlorine to keep the FC up. As the algae is killed and cleared, you'll lose less and overnight with no sun will lose <= 1 ppm which is one of three indicators that you are done shocking.
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Welcome jmcologgi
    I'm a newbie pool owner also
    I had no clue what to with a pool
    At the end of April I had a green pool and I found this web site
    I listened to what the experts said and my pool went from green to Sparkling Clear in less than 2 weeks
    I spent about 150 to 200 dollars at most and half the cost was a test kit(best thing I bought for the pool)
    Don't try to mix what you read here and what the pool store says it wont work
    Trust these guys and your pool will be Sparkling Clear soon
    It worked for me
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    Jun 2013
    Broken Arrow, Ok
    19
    Quote Originally Posted by YippeeSkippy
    Well anything seems like a lot of money when you've already drained the pool halfway and added several hundreds of dollars in chemicals. I'm so glad I found this site when I did or I'd have copper in my pool and who knows what else!
    Jun 2013
    Broken Arrow, Ok
    19
    So per advice yesterday we drained a third of the pool and now my CYA is close to the 40-50 range. I've added the amount of bleach suggested and an hour later about half is still there. This is a big improvement from before so I am making headway! I'm dying to get my test kit in to see more accurate test results but until then I'll do the best I can.
    In everyone's experience, how accurate is it to get the FC level tested at the pool store? Can they measure levels higher than shown on the yellow OXO test??
    Mar 2007
    San Rafael, CA USA
    12,082
    Pool stores often do the tests inaccurately. They usually have temporary help during the summer, they are not well trained, and they don't always use the best test equipment. For FC, they often use a DPD test and it bleaches out at higher chlorine levels above 5 or 10 ppm depending on brand. So no, I would not rely on the pool store for testing. Get yourself either the TFTestkits TF-100 or the Taylor K-2006 where the former has more volume of reagents you use the most (see Test Kits Compared). I wasn't clear if you had ordered it yet. If you ordered it from TFTestkits, you will get the test amazingly fast.
  20. Back To Top    #20
    38,235
    They usually only test up to 5ppm, because they use the OTO or DPD test.
