Thread: Best Way to Add Bleach?
    Mar 2013
    CT
    348
    With an in ground pool, is the best place to add bleach directly into the skimmer with the filter running??
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Best Way to Add Bleach?
    We recommend pouring in front of a return eyeball-----preferably aimed up to the top of the water a bit to ripple it.
    What woody said works great !!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Feb 2012
    San Jose, CA
    76
    With 4 returns, I put about 35% and 35% in front of the two deep end returns, 20% in front of the shallow end return, and 10% in front of the shamu-shelf (super-shallow) return. I've also tried pouring continuously around the edge of the water, still putting most of it in the deep end. Thoughts?
    (I also dunk the chlorine bottle a bit after I'm done, to get rid of any drips).
    Filled 5/1/2013! 36k gallon 20x40 IG with 7x7 spa, FinestFinish, AquaMatic cover, All Pentair: Clean&Clear 520 sqft cartridge filter, Intelliflow 4x160 variable speed pump, 2 HP whisper flow spa jet pump, 400k BTU MasterTemp heater, Letro Platinum pool cleaner, Rainbow 320 chlorine feeder, Pac Fab Bermuda skimmer
    More details: pics-new-pb-20x40-ig-gunite-7x7-spa-7x7-shamu-shelf-t54952.html
    Into a skimmer works pretty well, too. I like to do that in the hope that any algae that might be hiding out in my filter is gonna get really zapped.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
