Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Outdoor music setup.
    So we installed a pool last year and am now looking for a outdoor speaker setup and want to see if I am on the right track. Here is what I want.
    1. Internet radio with ability to play off home network, USB or iphone
    2. 4 total speakers and 1 sub
    3. Preferably the reciever be inside but controlled outside
    4. total under $600
    Here is what I have came up with
    1.Onkyo TX-8050 - http://www.amazon.com/gp/aw/d/B004UR486 ... m_sw_su_dp
    2 .Yamaha NS-AW150W http://www.amazon.com/gp/aw/d/B0001VHAR ... m_sw_su_dp
    3. 2 tic speakers. Either http://www.amazon.com/gp/aw/d/B0007RSZX ... m_sw_su_dp or
    http://www.amazon.com/gp/aw/d/B00006JQK ... m_sw_su_dp
    4. Tic sub woofer. http://www.amazon.com/gp/aw/d/B00009UI6 ... m_sw_su_dp
    Will this setup work and sound decent? I don't need blaring sound but quality is more important. Also I will be doing the install and am very comfortable with any wiring/ running wires. Does have to be weatherproof or atleast 2 of the speakers do.
    Thanks
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Jan 2011
    Richmond, Texas
    595
    Re: Outdoor music setup.
    Are you sure that receiver is going to be big enough to push 2 sets of speakers? How far is your run from your receiver to the speakers? My speakers are a long ways from the receiver and I have to turn the volume up high to get a reasonable listening level. BTW - I had the Yamaha NA-AW150W speakers at my old house and they sounded good. I would have used them again, but I did not have a easy way to wire them up under the eves.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Quote Originally Posted by Flippy
    Well that is one of my questions. Will that receiver work? The farthest run would probably be 125 feet of wire taking into account through the attic, up and down the walls, and around the concrete. I plan on using 12 gauge wire which I could probably get away with 14 but I use 12 even on my inside system because it sounds better IMO. Good to hear about the Yamaha speakers. I am also considering the polks as they are military grade water and dust proof.
    Apr 2013
    Tuscaloosa AL
    2
    Not an expert. My setup is a Denon 3312 which has 3 zones. Setup the second zone for pool area. Not 5:1, but purchased 130 w outdoor speakers from HD run is 100ft+. Added Apple TV as asource as well as Xbox, cable, also has a great HD/Net which give Internet radio as well as local am/fm. The great part is I can play ITunes through Apple TV source or switch sources while sitting at pool with app. If the onkyo has the ability to control via iPhone and the ohms are paired with speakers you should be ok. I would pump the wire up 14 or 16/2 maybe overkill, but pulling wire is a pain and always overkilled that myself.
    27k Free Form IG Plaster Hayward Sand Filter Polaris 280
    I have an Onkyo system with a similar setup: Onkyo lives in the attic, zone 1 in living room, zone 2 outside.
    It works, except when it doesn't. Then it's a pain because I have to go up into the attic and futz with it.
    When this system dies, I'm going to a Sonos. I've decided that simplicity rules.
    12000 Gallon Freeform Pool
    SWG
    Jandy AquaPure 1400
    Leslie's DPD Complete Chlorine Kit + FAS/DPD Chlorine Tester and Swirler from TFP.com
    Tree covered lot - cottonwoods and crepe myrtles. Great shade during the summer, miserable fall cleaning leaves from the pool.
    Quote Originally Posted by LynnOnTheWeb
    Do you control it with the app? I have read mixed reviews about the app just on the App Store but it looks like most didn't read and their receiver was not comparable.
    Quote Originally Posted by Jkhubbard
    Yes I plan on using just the app to control it. Also plan on using 12 gauge wire. I like overkill as well and have always used 12 for any audio throughout the house.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I wanted some music outside but hated the idea of running wires. I have a server with about 50,000 songs. I use iTunes on the server to share the music. I use my iPad as a jukebox and connect to the server's itunes over my home network then the Ipad streams the music wirelessly to my Pyle Pro PA system. You can see this PA at the link below. This thing ROCKS!!! It has a 15" woofer so the Bass response is amazing. It is on wheels so I just roll it out to the patio when we want some tunes. The only wire is a power cable. My neighbors hate it. In addition to Bluetooth connectivity, you can use a USB thumb drive, or SD card. It also has RCA inputs and XLR inputs for a microphone. My nieces love to use it for karaoke. I love the fact that I don't have to worry about the hot Louisiana sun destroying it from being outside all the time. I found this unit for $225 plus shipping.
    http://www.amazon.com/PYLE-PRO-PPHP1537 ... yle+pro+pa
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Excuse me if this is a dumb question. But for what I am looking to do I don't want a home theater surround sound av receiver do I? I have been looking at stereo receivers. And there are just a few in my price range that do what I need. No wonder everyone always just buys a surround sound in a box. Trying to piece all this stuff together isn't fun at all.
    Oct 2012
    604
    Yes, you want just stereo. I would recommend a nice used Harman Kardon since they have discreet amplifiers and can drive extremely low impedence loads which you will likely encounter with such long speaker runs, even using 12g wire.
    I use the TIC speakers for my setup. I have two of the GS-3 speakers (the bigger ones). I ran direct burial wiring and placed one on each side of the pool area in the middle. Using an older Onkyo surround sound receiver I had (75 watt I think), the sound is very good. Noth bass thumping good but plenty loud to the point where I usually run at half volume when in the pool and 1/4 volume when we are sitting on patios talking. I am currently using my older Logitech Squeezebox radio hooked up to my reciver which allows me to play my home media, internate radio and Pandora. Using an Iphone app, I can completely control it from my phone.
    I was considering adding the TIC subwoofer but I haven't seen the need for it. Unless you are looking to blast music and "feel" it, I don;t think it's terribly necessary.
    My one issue with my setup is that I can only send a stereo signal to the speakers. So when sitting closer to one side, you may miss out on some of the music being played. Lot's of older classic rock I like uses distinct stero recording so a guitar might only be coming out of one channel. My receiver does not allow me to swap the output to mono and I haven't really tried playing with how I have speakers wired to overcome that issue. In general, it sounds great but there are those times where I wish I could output mono.
    I am intrested in what you go with for the internet radio option. while the Logitech serves the purpose today, it is no longer supported by logitech. I believe another compnay makes a radio that is alsmost identical (Grace digital) that also has an app but there must be other good options out there.
    2012 (late install) 20x40 inground Oasis steel pool with vinyl liner. Pentair DE Filter with Whisper Flow 1HP pump and Pentair 400K BTU heater.
    2016 Marquis Promise Spa (2 pump model)
    Quote Originally Posted by kyle11
    I do control it with an app. I use "Remote2" (has Onkyo on the icon, but not in the name) instead of OnkyoRemote most of the time.
    Both of them work mostly well. They used to be buggier, but now they're workable. I think the biggest problem I see now is that you often have to completely quit out of the app between uses (you know, when you make the apps wiggle, click the X to close, then reopen). It seems that if you don't do that, it often times can't find the receiver again. Because it happens with both of them, I tend to believe it is something with the firmware in the Onkyo, not app related. I updated my firmware about 2 months ago and it's gotten better. I used to have to do it every time, now it's just on occasion.
    There have been a couple of times that the remote apps didn't work. A complete shutdown/restart of the stereo got it working. I'm guessing that the internet connection just needed resetting.
    All in all it's good system, but it's not for the faint of heart. Non-techies would probably not like it. It's just too complicated to run, especially if you've got the receiver hidden away in an inaccessible place.
    Hope that helps.
    Lynn
    SWG
    Jandy AquaPure 1400
    Sep 2011
    Zebulon, NC
    24
    Have you checked into the HDMX Jam speakers? http://www.amazon.com/HMDX-HX-P230GY...3&keywords=jam
    admittedly its completly low tech but they actually sound pretty good and you can get decent volume from them. If you have an old android phone that you can get wireless setup to stream or play from the cloud then you have a pretty good solution.
    I was contemplating the same thing last year. Finally I decided to go with a Sherwood Amplifier:
    http://www.amazon.com/Sherwood-RX5502-D ... l+sherwood
    -its 4 channel by 100watts which means you can rock 8 speakers in your backyard depending on how loud you want it. (or you can do 4 in backyard and 4 in garage if your going to run it through your attic like someone previously stated which is what I did). Its great because its just a "stereo receiver" not all the extra connections that you will pay for and not even use.
    Then I use a SONOS Connect to access all my music via HiFi. ( I was so impressed with sonos I ran it through my entire house, ITS AMAZING). I can change songs from the pool while floating around drinking a beer, or anywhere throughout the house for that matter.
    As far as speakers I just went with 2 pairs of the $100 pair rock speakers from best buy ( on sale for $90). I tried out the sound quality there compared to several others and decided that it was suffice for an all year weather speaker. Boy am I glad I did not waste $300-$400 a pair for some other brand because they are still thumping!! I also was not excited about having to mount something else behind my siding either (just the way my backyard is set up).
    Also a little trick I learned was using low voltage wires. The same you would buy for installing landscape lights. One of my speakers are ran for over 300ft and there is no distortion whatsoever. Its the same as speaker wire just a fraction of the price.
    Hope this helps a little.
    -Jeremy
    28K Gal, IG Vinyl, 1.5HP Hayward Super Pump, Hayward DE Filter, Hayward Gas Heater, Hayward off line Chlorine Feeder, Polaris 380 cleaner with PB4 Booster Pump.
    Oct 2012
    604
    Sherwood used to make really good equipment and they most likely still do. I worked in electronics in the 80's and Sherwood was the industry secret. They used no IC's in the signal path. Everything was discreet and they could easily drive a 2 ohm load. Harman Kardon and just a handful of other makers could make this claim. Good stuff and highly recommended.
    Jun 2013
    Philadelphia, PA
    143
    I'm late to the party, but just saw this thread. Whatever you do - check out Sonos. Just installed it (Just the amp) with two SpeakerCraft speakers. OUTSTANDING! Sounds is fantastic, Sonos is simple to use, and I can put the app on anyone's phone so they can play music.
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I have a similar setup. I have the yamaha speakers you listed and two TIC GS 3's. My receiver is Pioneer:
    http://www.amazon.com/Pioneer-VSX-822-K ... =pd_cp_e_1
    I used direct burial landscape wire for the GS 3's.
    I also suggest adding a volume control so that you can turn down the yamahas and turn up the TICs. I used two of these inside a dual gang box:
    http://www.homedepot.com/p/Leviton-Deco ... /100602408
    http://www.homedepot.com/p/Red-Dot-2-Ga ... /203984747
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2013
    Erie pa
    68
    i have a sonos setup with outdoor speakers and i love it.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    I ended up going with the onkyo tx8050 which has interent radio and a app so I can control it while at the pool. I put the receiver in our bedroom and ran the wire through the attic to 2 tic gs3 speakers about 50 feet from the house in 2 flower beds. Also got 2 polk audio atrium 4s which will be on the back porch but have not hooked them up yet. Just with the tics it sounds pretty good. Gonna have to play around with the settings to get some good bass out of the tics but it should get louder when I put the polks up enabling me to turn the volume down and the bass up a little. It costs me right at $500 for the set up.
  20. Back To Top    #20
    Here's a few pics of the setup. The view is from the cozy cove of the pool.
    The polks are mounted on the porch and the tics are in 2 flower beds on the other side of the pool.
