Thread: diving board - fibreglass cracked
    [attachment=0:32n0u8zl]diving board closeup.jpg[/attachment:32n0u8zl][attachment=1:32n0u8zl]diving board.jpg[/attachment:32n0u8zl]
    noticed recently that the underside of the diving board has cracks in the fibreglass
    local store says not to use as "butcher block" wood will break - the grain in the wood looks like two long boards to me, however
    local store wants close to $800 for cheap new board (10')
    my kids say the cracks have been there for years
    should this be replaced?
    should I simply limit use to small kids? (had some adults use it this past weekend, though)
    is there any type of fibreglass repair I can make?
    any thoughts out there would be appreciated
    May 2013
    North East Ohio
    959
    Re: diving board - fibreglass cracked
    You can repair fiberglass fairly easily -but since I don't have it in front of me, not sure if those are structural or not. The repair may or may not hold up.
    However, if your kids said they were there forever, I would try fixing...much cheaper than $800. You can google fiberglass repair, but basically you "roll" on the resin then layer glass, resin, glass, etc.
    Most marine stores or even auto body stores will have all the stuff you need.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Personally I would not chance it and would replace or remove the diving board, the original diving board on my pool snapped in half when it was about 8-10 years old while a 270 pound man was jumping on it, since then when cracks appear I have decided to play it safe and replace the board.
    Ike
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    419
    The Mat fiberglass used is STRUCTURAL meaning its one piece layered. A patch will not work.
    Chuck it before someone gets hurt. Look on craigslist for a used replacement.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    thanks, i appreciate the responses
    all over CL....
    Jun 2013
    Huffman Tx
    190
    your ins. co would drop you
