Thread: Acid
    Acid
    our Akalinity is high. The solution is acid? Can you use acid on a vinyl liner?
    Thanks!
    15 x 30 oval above ground, 13000 gals, 1 HP pump, sand filter.
    30,421
    Re: Acid
    Actually the solution is in an article in Pool School. You will find it is an acid/aeration process and perfectly safe for a vinyl pool.
