Thread: aeration defintion?
    aeration defintion?
    what does it mean when the calculator says to aerate the pool. My PH is at 8..says to lower to 7.0-7.2 then aerate? not sure what that means.
    thanks
    25k, IG, fiberglass walls and plaster/cement steps and floor, DE, 3/4 HP Heyward motor, Heyward automatic chlorinator, Pool is about 20 years old.
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Re: aeration defintion?
    It's any process that results in air being mixed with your pool's water. This can be done by a number of ways, such as using a waterfall feature, turning on your spa's air pump (if you have one) or altering the flow of water from your returns to break the surface of the water. For maximum aeration, you want to see lots of bubbles. The idea of using aeration to lower TA is that aeration raises pH; adding acid lowers both pH and TA. Aerating over a period of time while continuing to add acid will lower TA and keep you within a safe pH level.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
