Results 1 to 13 of 13
Thread: CYA reference solution question
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Would diluting the 50 ppm CYA reference solution 1 to 1 with tap or distilled water create a 25 ppm CYA reference solution?
    thanks Ike
    30,403
    Re: CYA reference solution question
    Maybe, but more importantly, the K-2006 and most CYA tests only read down to 3o. The TF-100 does go to 20 but I see little reason to test repeatedly that low.
    Butterfly's Avatar
    South Carolina
    10,045
    Could be very helpful for an indoor pool.
    You're done SLAMing when:
    30,403
    With an Accuracy of + or - 10 ppm, I just don't see the need.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my case with an indoor pool I try to maintain a CYA level between 20 and 30, the addition of a 25 ppm reference would potentially make this an easier task as it removes or at least lowers one more variable.
    38,248
    How long does this stuff last? Does it go bad?
    Years.
    38,248
    Maybe a silly question, but you do not mix it with anything right. You just test directly and then in reality it is never consumed.
    Seems like someone in Tucson should buy this
    No, it gets mixed with the CYA test reagent exactly as if it was pool water. The mixture lasts 5 or 10 minutes and isn't useful after that.
    38,248
    OH ... got it.
    Is the 5-10 minutes true for the regular CYA test? Not sure I have gone that long, but often it sits for at least 5 minutes before I get around to going outside to do the test.
    Yep, 5 to 10 minutes from when you are done with the 30 seconds of mixing. The water sample from the pool can wait a long time before you add the CYA test reagent without problems.
    38,248
    The engineer in me may just have to test this time limit ......
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The whole point, I thought, was to perfect your testing technique.
    If you mix it up as directed and get something besides 50, you need to change the lighting or how far you hold it or decide just how invisible is invisible.
    Once you get 50 consistently, if you repeat the test under the same conditions, your CYA reading should be accurate no matter what the CYA level is.
