Thread: DEDICATED VACUUM LINE
    I have a dedicated vacuum line that is pulling just a little bit of air, but when I hook up the vacuum hose to it the pump loses its prime and will not fill back up until I pull out the hose. Any advice.
    IG 28x40 true L vinyl liner 35,000 gal. pentair 1.5 hp pump 3 skimmers 2 return lines 1 vac line 2 step jets
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: DEDICATED VACUUM LINE
    You probably have a leak. The extra restriction from the vacuum line is causing increased suction and it draws in more air. Like trying to drink through a straw with a hole in the side.
    Makes sense when you explain it like that. Thank you for your reply!
