Results 1 to 7 of 7
Thread: Panyhose,Knee high and Skimmer bag sock???????
    Can yall post some pics of the way you use these in or around your skimmer basket. I would like something a little finer then my strainer in my skimmer to catch the debri if possible.
    18' x 52" Intex Ultra Frame, Intex Sand filter 2650gph pump with saltwater generator,lady bug automatic vaccum cleaner, Hydropools wide mouth skimmer, all hard plumbed 1.5" PVC
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Panyhose,Knee high and Skimmer bag sock???????
    Richard320 posted some pics here:
    skimmer-sock-nylon-illustrated-t60819.html
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Thanks for the fast responses. It just seemed like it should sit in the basket not stretch so tight over the top. Thanks again
    Jan 2013
    Houston, TX
    1,079
    I use one in my Polaris 280 as well.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jul 2010
    Jacksonville, NC
    35
    Lowes or Home Depot = Paint section = 1 gallon paint stainer works well.
    24' X 54" Sharkline Matrix. J-Hook liner.
    2 speed pump, 16" Intex sand filter.
    I went out and bought the paint strainer from Lowes so we will see that should help alot. Last night I also had to take apart my whole system and clean all my sand filter it was all plugged with grass clippings and leaves in the strainer inside the top valve assembley of the sand filter because of not having a finer filter
