Thread: Pool store testing
    May 2013
    Rochester, NH
    18
    Pool store testing
    If I ask the pool shop to test for these items(CYA) and they comply, will those results be reliable? Or only results with your own kit is trustworthy?
    Tyffany
    20k gal, IG Vinyl, 1 HP Hayward superpump, Foxxx sand filter model F3-24-63 ~Southern NH
    38,475
    Re: Pool store testing
    As stated in your other thread ... we do not trust pool store testing ... there are 1000s of threads that confirm this conclusion.
    BTW, CYA is the test that the stores are notoriously the worst at ... they do not use the correct lighting.
    May 2013
    Rochester, NH
    18
    Ok.. Got it. Pool stores suck at correctly testing water.
    Tyffany
    38,475
    Most do yes. Take the same water to 3 different stores and get 3 different answers. Take a sample back the next day to a different employee and you will get results that are not possible to change overnight.
    They also do not use the FAS-DPD chlorine test ... so they are limited to max of 5 or 10 ppm and are then just trying to match colors.
    Trust your own testing. Period. It is more accurate and repeatable.
    Since this is my first post... HELLO!
    I understand there may be some shady pool companys but I have to say that the pool store (not sure if I can give the name but it's Town and Country in Phillipsburg, NJ) that installed our ABG 21"x54" (and it rocks). They use "ClearCare Expert" testing system. Since the day they installed our pool, advised on closing it last year and what to do to open it this year they've been spot on with their advice. Water is crystal clear with no issues.
    I go weekly to Town and Country who tests for: Free Avaliable Chlorine, Total Chlorine, Combined Chlorine, PH, Akalinity, Calcium, Cyanuric Acid, Copper, Iron, Manganese, Nitrates, Total Solids, Phosphates, Salt and Saturation Index - for free. Since I'm there I can pickup chems.
    I use a cheapo testing kit 3 way test kit for every other day testing.
    Before lumping pool stores into the same grouping as ambulance chasers I would recommend you ask about their testing process - what do they test for and how often do they recommend you test. And talk to some of their customers in the store about their experience
    Got to work on my sig... 21'x54" ABG with Hayward SP1510 pump with a Hayward S180 Sand tank, using chlorine. Looking at a heatpump to extend my swimming season.
    21' AG (~11,000 gallons)
    Hayward S180T sand filter (35 gpm)
    Hayward Power-Flow SP1510 pump
    Asking is useless unless you know what you are talking about and can distinguish a good answer from a bad answer.
    There certainly are some amazing pool stores out there, but the great majority are staffed by people who learned about pools by reading product labels and know less than you can find out by reading Pool School for an hour or two.
