Results 1 to 12 of 12
Thread: 2 of 3 B's?
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    2 of 3 B's?
    Is is alright to use the borax and baking soda, but still use my chlorine feeder? I don't know if I'm ready to give that up, its just too convenient. I find that my CYA level stays at around 40 all the time.
    17,000 gallon roman shaped gunite pool-AquaRite goldline SWG
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    As I've read here several times "Chlorine is Chlorine". If you are not seeing any CYA increase and you are using trichlor pucks you must be replacing enough water through backwash, splash out and evaporation to keep CYA steady. The other possibility is Cal hypo pucks which won't increase CYA but will increase Calcium hardness. If thats the case you need to watch your CA level. There is no penalty for being only a BB.
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    Jun 2007
    SF Bay Area
    441
    teppy,
    If you REALLY are able to keep your CYA at 40, then you should be able to keep using the pucks and chlorine feeder. But realize that you will be spending quite a bit more money on the chlorine pucks that you would on liquid chlorine.
    You can lose CYA through backwashing and splash out. Evaporation, unfortunately, has no effect on CYA levels.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Trichlor and bleach actually cost about the same if you ignore the cost of water replacement to keep the CYA level from getting too high and borax to keep the PH from getting too low.
    There is simply no way that CYA can remain constant when using a trichlor tablet feeder. CYA might go up slowly enough that you can live with it for quite some time but CYA will go up.
    In any case none of that has anything to do with borax and baking soda. Both of them are fine to use with any source of chlorine.
    Ohio
    217
    teppy... there is nothing wrong with using the pucks. Testing is the key to the pool, watch the CYA if you get to 50 I would stop using the pucks. Also watch the PH it will probably fall some, the pucks are acidic as you probably know and Borax would be a good choice to raise the PH. The Baking soda will raise the PH but also raise your TA.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    I don't know how my CYA stays in the 40 range, I only add water about once every week and a half or so, depending on how much it rains. My Ch stays at around 250. I have a raised bond beam with two spillways. I don't know if that helps or not.
    30,426
    Teppy,
    DITTO! I am repeating Jason's words for emphasis.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I use trichlor pucks and bleach.
    My pool starts out with 0 CYA when we open in April. I add enough to get CYA = 30. At the end of the season it runs at CYA = 40 and that's what I close with. Beats me what happens to that CYA over winter.
    At any rate, my feeder is set to 1/4 flow and I add liquid bleach to maintain a FC = 3 level. I rarely shock, if ever. With the dogs I do get a lot of backsplash which requires refilling at least once a week.
    YMMV. In our pool and with our usage the trichlor has not presented a problem.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    krcossin's Avatar
    Detroit Burbs
    113
    I use bleach most of the time, use the trichlor pucks in the feeder only during the vacation weeks.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    IkeRay's Avatar
    Houston, Tx
    154
    krcossin, might I suggest using Cal-hypo pucks instead of the trichlor when you are away.
    my reasoning, CYA is best in a 20ppm range (30-50/60-80), while CH is a 200ppm range (250-450 is acceptable). each tablet pretty much adds 1ppm CH or CYA per. so after 1 week, assuming going through 3 tablets, you have gone up 15% CYA, or 1.5% CH of acceptable range.
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Cal-hypo puck tend to be difficult to find and, more importantly, tend to dissolve way too quickly to be suitable for vacation usage.
    Guest
    Quote Originally Posted by IkeRay
    recheck you math on this one!
