Results 1 to 15 of 15
Thread: How to wire 2 speed pump
    i am having the same problem on how to wire ? two hot wires land where ? and no nuetral from gfci breaker to pump?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Hayward Superpump 2-speed 230V 1HP wiring help
    Quote Originally Posted by bnterrill
    Hots are L1 and L2 or Line1 and Line2. No neutral on a 220V setup.
    38,248
    One line should go to L1, the other line should go to the center of the switch.
    That diagram is not very good.
    The switch is full. Came like that from the manufacturer. No where to hook another wire
    22,542
    One hot goes on terminal #1 and the other hot goes on terminal #3 or #4 whichever it's labeled in the motor. The switch is already wired internally.
    Ok did that. No. Motor doesnt run. But i can manually trip gfci breaker by hand so i have power to breaker
    22,542
    The speed switch should have three(3) positions; low-off-high. It isn't on off is it?
    Did you try both high and low?
    My switch feels like it only has two positions. I will try again later. So out of my gfci breaker what do i do with my nuetral. Dont use it?
    Its only a 2 position switch
    A photo if the wiring and the wiring diagram on the motor would help.
    38,248
    Mine only had 2 positions as well and I had to connect the second line to the middle of the switch. Where does the wire from the middle of the switch connect?
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Superpump has 2 position switch and power should go to L1 and L2. Did you test the lines going to the motor terminals to make sure you have power directly to the motor?
    Mark
    Re: How to wire 2 speed pump
    Wire from the middle of the switch goes to L3 terminal. I just dont wanna hook this up wrong and burn it up. I am pretty sure the incoming leads r hot but i cant test it right now i am at work. Plus i am working on uploading nameplate w diagram and picture of peckerhead.
    Did you ever get this resolved? If so, would you be able to post pictures? I'm dealing with the same issue.
    77000L (20500 gallon) Vinyl in-ground chlorine pool, 35'x,17', jandy stealth 1hp pump, jandy lite2 LJ400N heater, jandy st-t sand filter, Hayward chlorine feeder.
    Dec 2009
    Central Massachusetts
    2,690
    Generally, a 2 speed has a common that is on #1, a "high" terminal and a "low" terminal. The switch takes one hot lead off the breaker and splits it between the high and low side windings. The other hot lead from the breaker goes to the common terminal. No neutral.
    Like jason said, post up a wiring diagram.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
