Thread: Should I put my heater inside?
    Clarksville, TN
    126
    Looking to buy a heater soon and I am debating if it could go inside with the rest of the equipment. I assume it would need to be vented. I was thinking it may fit to the left of the filter. Any expert thoughts?
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Re: Should I put my heater inside?
    JAnthony,
    Without question, heaters require clear, open, unfettered, unhampered air space all around them.
    I would suggest you haven't sufficient room to install the heater inside your shed.
    Further, it would block access to everthing else in its area.
    And you didn't mention whether the heater would be wood-fired, coal, fired, propane, natural gas, solar-powered, or 220/240 electric-powered.
    Each of those will have very specific intalllation instructions, and I personally don't know of any that are to be installed indoors. You are dealing with plastics and wood, and coated wiring, which can melt and burn, and I don't believe you can "fire-proof" your shed.
    Perhaps someone else has additional info....
    Beautiful set-up, great plumbing job, too.
    Alan
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    Jun 2012
    western NY
    1,560
    Gas fired can most definatly go inside a structure. You will need to be aware of the type you purchase to make sure it comes with a proper vent kit for it. You will also have to check on clearances needed. All units will come with a spec sheet that tells you what clearances are needed around all sides as well as around the venting system. I would also suspect you will need to move the control circuitry you have mounted on the wall in that area.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Nov 2011
    Moberly,MO
    1,010
    Without knowing specicfic measurements I don't think there is enough room to get necessary clearances to meet manufacturers requirements. Most heaters will require 18" to combustible materials.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Besides the spec sheet you should also check on any code compliance issue there might be by having it enclosed and if any code clearance requirements would be greater than the minimum the manufacturer recommends.
    Solar Blanket, Well Water, Borax Added. 68
    In my opinion, the best thing to do would be to consult a local HVAC contractor as to what your heater options are.
    Support the site
