Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Rebuilding SWG cells
    Sep 2009
    Houston, TX
    117
    Quote Originally Posted by Strannik
    well...
    it's not worth it
    majority of the cost is in the plates as the coating has precious metals in it (ruthenium oxide or iridium oxide)
    non-self cleaning cells can be reconditioned, as half of the plates are just bare titanium, so you can just replace the anode.
    however with self cleaning ones you have to replace all the plates which only leaves the cap and connectors that can be salvaged.
    also not all cells last 3 years and not all of them are expensive
    So I haven't been able to find any discussion, beyond the few comments here, in regards to rebuilding these cells. While perusing ebay for a replacement t-15 cell I stumbled across salt solutions inc. They claim to be able to rebuild the unit for $275, around half of what a new one would cost. They also include a one year warranty. I was wondering if anyone has had any experience with going this route before I decide to pull the trigger. See here for further info https://www.saltsolutionsinc.com/repair ... -15-detail
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
    38,284
    Re: Cell life?
    That is interesting, although I wish they provided more information on how they are repairing the cells.
    {Also the grammar in the first sentence annoys me }
    Sep 2009
    Houston, TX
    117
    Re: Cell life?
    I'm trying to fix a pool here....not write a book. I did email the company to inquire what their rebuild process actually looks like.
    38,284
    Re: Cell life?
    Sorry ... I meant on their webpage at the link you posted
    Nothing says "professional company" like typos/bad grammar in your marketing material.
    Sep 2009
    Houston, TX
    117
    Re: Cell life?
    They also have an ebay store with many satisfied customers. From the feedback looks like they've been selling them since mid 2011. http://www.ebay.com/itm/261072730054?ss ... _317wt_646
    Sep 2009
    Houston, TX
    117
    Re: Cell life?
    Response from the seller "The only thing we re-use is the P.V.C. outer housing and the plug in cord. All internal parts are brand new from the mfg. and fully warranted for one year ( an extended warranty is available). We buy better plates which are rated for 10,000 hours of usage while most out there are only rated for 8,000 hours…….the plug to the controller stays with the cell." I think I may give this a shot.
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    Re: Cell life?
    Eric:
    Have you gotten a cell from Salt Solutions? How's it working out?
    21,000 gallons
    Pentair 420 Clean & Clear Plus Cartridge Filter - Filter Area: 420 - Design Flow: 150
    Inground Plaster
    Pentair Whisper Flo Pump - 1 HP - Model CCP420
    Pentair MiniMax NT Series Pool Heater
    Aqua Rite Electronic Chlorine Generator
    Polaris 280 Cleaning System
    Sep 2009
    Houston, TX
    117
    Re: Cell life?
    received and installed and all seems to be working fine. Getting proper voltage readings again. You can observe on the housing where it's been cut open to remove the guts. The real test will probably be time.
    Re: Rebuilding SWG cells
    I just ordered mine from them today. My 6 year old cell says there is 2200 ppm salt in the pool and my taylor drop test kit says 3500 ppm. No more generation...
    22,000 Gunite, Cart Filter, Aquarite SWG
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I would be happy getting 6 years out of my cell ...
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    I could have replaced it last year but just ran the salt high. The SWG would say 2900 but the pool was really at 4000. We have had a ton of rain and I figure I should just fix it right.
    Oct 2007
    Valrico, FL
    542
    My cell has about six years on it, and is still going strong. However I have a small pool, and so run the filter for seven hours each day with the SWG set at 25 to 30%.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Jul 2007
    Brisbane, Australia
    874
    i've seen customers getting up to 15 years out of the cells. the most common is about 5 though
    Apr 2012
    49
    I know this is an older thread, but I just wanted to add that I purchased a rebuilt cell from Salt Solutions Inc. in March of 2012 and it is still running strong.
    ____________________________________________________________ ___________________
    21,000 gallon in ground rectangular plaster pool, Sta-Rite High Rate Sand Filter Model 82524-3, AO Smith SK1152 1.5HP motor w/ Sta-Rite bronze pool pump, Hayward Navigator
    Mar 2014
    Raleigh, NC
    16
    I started a thread today about my failing cell and asked about the rebuilt cells as an alternative to new. 2 years in Tuscon is a pretty good testimonial. Any one else willing to endorse these rebuilt cells from Salt Solutions?
    Sep 2009
    Houston, TX
    117
    Almost up to two years now with continual year round usage. Still working great.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Thank you for following up. I'm glad it is running strong.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Sep 2009
    Houston, TX
    117
    Figured I would report a failure. Lasted a bit over 2 yrs. A bit disappointing as I have a small pool and typically only run it at about 10%. I would say the service life was significantly reduced over what is expected.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Mark
  20. Back To Top    #20
    Sep 2009
    Houston, TX
    117
    Salt level was not reading correctly. It was reading way lower than the actual salt level so I kept needing to add more salt to get it to limp along. But I did find it odd that the amps and volts stayed the same after replacement as I thought the salt level was calculated off of these readings. For my unit it was still reading nearly the same before and after replacement (25V 8.25Amps or so).
