Results 1 to 7 of 7
Thread: Motor wire help
    Motor wire help
    How should I wire this motor? It is 2 speed OAsmith with timer 3/4 hp. I understand the ground wire is connected to green screw. How do I connect remaining two wires?
    12,750 IG plaster/pebble. 1 HP uprated Duraglass pump. Cartridge filter.
    May 2012
    North of Charlotte, NC
    312
    Re: Motor wire help
    220V motor ? 110V ? When you say "with timer" is it powered by a separate timer like most or is there an actual built in timer ?? There is usually a wiring schematic either on the motor data plate or sometimes on the back of the cover plate , it either a picture would help a bunch as well....
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Motor wire help
    The manual has the wiring diagram on page 7. http://www.pentairpool.com/pdfs/DuraGlasOM.pdf
    May 2012
    312
    Re: Motor wire help
    Quote Originally Posted by Richard320
    Walla....And there ya have it
    Re: Motor wire help
    Thank you Richard320 and Roadking00! your help is much appreciated.
    38,475
    Re: Motor wire help
    Did that work? That diagram looks to be for an external speed switch and if your pump has the timer and speed selection built-in, then the wiring may be different (like a regular 1-speed likely).
    There has to be a diagram on the large white plate on the side of the motor.
    Re: Motor wire help
    I think you are right. The diagram shows only line connection at L1 and L2 and ground at green. It is a 2Green AO Smith motor with internal timer built in. Diagram does not show any connection at 4. I have not tried to connect it yet because I just discovered that my existing motor is 115 and I was dead sure it is 230V. I am in the process of learning how to wire my panel for 230V and I was confused because youtube instructional was showing 2 hot wires connected to 20 amp breaker and a ground. So it was only 3 wires instead of 4 wire connection suggested by wiring for 2 speed motors without built in timer. Thanks jblizzle for the info.
