Results 1 to 9 of 9
Thread: Pumps
    Apr 2012
    Wantagh ny
    4
    Pumps
    Looking to find out the big differences between Hayward's variable speed pumps
    Sp2300vsp
    Sp2600vsp
    Sp3400vsp
    Sp3400vspvr
    Any help would be appreciated
    36x18 hard bottom vinyl liner pool w/ 10x12 L shaped jacuzzi access stairs
    28/28 mil looploc liner
    1 1/2 in PVC pipes w/ 7 jets
    Hayward 4280 de filter w/ Hayward sp3400vsp ecostar variable speed pump
    Hayward h300 gas heater
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pumps
    Each pump uses a different wet end from another pump line
    Sp2300vsp- Uses the Maxflo wet end - Targeting AG pools
    Sp2600vsp - Uses the Superpump wet end - Targeting small IG pools with small plumbing
    Sp3400vsp - Uses the Tristar wet end - High efficiency pump targeting higher flow rate applications
    Sp3400vspvr - Same as above but with a vacuum release safety system - Targeting spa applications
    What is your application? Please fill out your signature with your equipment.
    Mark
    Apr 2012
    Wantagh ny
    4
    Re: Pumps
    Thanks mark so what do you think
    I bought the house 2 yrs ago and it was my 1st pool
    Talk about getting thrown into the mix not to mention liner went
    When I opened it up this year it was 12 yrs old
    Thanks for any insight
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pumps
    The SP2600vsp would be closest to what you have now and you could possible use the same wet end so you wouldn't need to do any plumbing work.
    What do you pay for electricity and why are you looking a VS pumps?
    Mark
    Apr 2012
    Wantagh ny
    4
    Re: Pumps
    Electricity is pretty high on Long Island NY
    I'm paying a little more than .09 a KWH
    Was looking for variable speed for energy efficiency
    And I was putting in a geyser effect in the deep end so I can control
    The amount of pressure for that effect and the hot tub jets
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pumps
    Quote Originally Posted by mas985
    Strange that they have it listed only under "In ground pools" section of there website...and the price which is comparatively high to other AG options.
    Looks like this one might be obsolete now?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pumps
    Quote Originally Posted by linen
    The MaxFlo II series is an in ground pump. The Power-Flo series are the AG pumps. Hayward has discontinued the sale of the MaxFlo non-VS pumps but you can still find them on the internet.
    http://www.hayward-pool.com/prd/In-Grou ... 3502_I.htm
    The SP3400 series is the EcoStar and they are still selling those.
    Mark
    Re: Pumps
    I'm totally confused. I just installed a sp2300vsp... Your first post indicates it's for ag pools?...
    It appears to be working well... What should I be looking at... I run a kreepy great white and a liquidator... Pool in sig
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    38,520
    Re: Pumps
    It is fine ... the 2 smaller VS pumps are very similar. Actually the Max-flo is slight more efficient and usually cheaper it seems.
