Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Green pool........... new pool owner
    May 2013
    Longview Tx
    21
    I am a new pool owner. I read threw the "shock Process" and I'm confused now.
    My water sample numbers are as followed
    FC=6.8ppm
    TC=7.7ppm
    CC=.8ppm
    pH=7.5
    Hardness=229ppm
    ALK=122ppm
    CYA=40ppm
    With chlorine numbers that high shouldn't I be winning the battle with the algae?
    Thanks for your help
    Jon
    31' round, 21k gal, AG, sand filter, chlorine
    Jul 2007
    Chicago, IL
    87
    Re: Green pool........... new pool owner
    The shock level is 16 ppm for a pool with a Cya level of 40, so no, you are not winning the war just yet.
    You'll need to check your FC level frequently, every hour at first, to ensure your FC stays at or above 16, adding chlorine if it drops below.
    Your results look like they came from a pool store, so the results might be questionable. We recommend ordering a good test kit. See the Pool School link for more info.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome to TFP!
    Quote Originally Posted by greenpool74
    Unfortunately the answer is no. "High" is a relative term. Your FC needs to be high with respect to your CYA level. At a CYA of 40, your FC needs to be at 15 for shocking.
    The higher the CYA, the better it protects FC from sunlight (which is good). The higher the CYA, the less FC is actually going to do the work of cleaning your pool (which is not so good). Hence, the higher your CYA level, the higher your FC level needs to be. This is the heart of the FC/CYA relationship.
    In your case, your CYA is binding up most of your FC. While some of the algae is dying, it is still multiplying faster than the FC can kill it, which is why you need to raise the FC level to 15 (or slightly higher). Hopefully Richard320 can get in here with either a battlefield or escalator analogy soon.
    Two questions while we're at it....How are you testing your water? Have you read through the Complete Table of Contents in Pool School?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    greenpool74:
    Welcome to TFP
    You are at the point I was when I first learned about TFP. The first step is you need to "unlearn" the old conventional (and incorrect) wisdom of maintaining an FC between 1-3 and anything above that is shock level.
    The proper FC maintenance and shock levels are dependent on your CYA level (refer to Chlorine/CYA Chart in my sig). Given your CYA of 40 ppm, your minimum maintenance FC level is 3 ppm and the ideal target FC is 5 ppm. Your shock level FC is 16 ppm.
    Given that your CC is greater than 0.5ppm, you need to go through the Shock Process (link in my sig) and aim for a target FC level of 16 ppm throughout that process. Before you begin the shock process, I would lower pH to around 7.2. This will make the chlorine more aggressive as a sanitizer. Once you begin the shock process, do not test pH as the shock FC levels can throw off the test results. You can retest pH after the Shock Process when FC levels return below shock level.
    Your ALK (TA) and Hardness (CH) look good.
    May 2013
    Longview Tx
    21
    Ok I went back and opened the "chlorine/cya chart". (I overlooked) Yall are correct I'm no where near the FC shock level. I'm getting a bit overwhelmed and am rushing my reading. I need to slow down lol.......... my daughter keeps asking why the pool looks like that. Thanks for quick replies. I will continue to read through entire table of contents under pool school.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    How are you getting the test results?
    May 2013
    Longview Tx
    21
    I am ashamed to admit it after reading the "recommended test kits", but I am using test strips and I went to pool store and had it tested :-/
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As the old saying goes, "Rome wasn't built in a day." You'll get there and your coming to the right place for help!
    May 2013
    Longview Tx
    21
    I have been battling between listening to an older gentleman tell me basically the "BBB" method and another guy tell me to "just go to poolstore". So Ive been caught inbetween.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Understand your dilemma. I don't convince easily either. I stumbled around during my first year as a pool owner under the "pool store method". But the more I read about BBB and the chemistry behind it, it made more and more sense and I took the leap of faith and have never looked back. Here's my Before & After story: http://www.troublefreepool.com/bbb-s...ar-t54033.html
    May 2013
    Longview Tx
    21
    So I went on line and ordered the TF100 test kit late last night. I'll be glad when I get that so I can more closely monitor my FC level. Any advice what I should do until test kit arrives? Keep adding bleach until green starts to fade?? Thanks in advance for help.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes I would say you could safely add a jug of bleach each evening until the kit arrives. You can also use the strips even tho not accurate to see if the FC is even registering at all....
    May 2013
    Longview Tx
    21
    According to my strips my FC is around 10 or higher. My three way test kit from Walmart indicates its way higher than 7. If my FC is higher than 16, shouldn't the algae start dying and pool color changing faster than what it is????
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Scroll through the thread list in the Algae Forum. Some people struggle for weeks to eradicate the green.
    It didn't get like that in one day, it will take more than a day to get rid of it.
    May 2013
    Longview Tx
    21
    ok finally I get to update.....
    just got my TF100 test kit in and ran the samples. results are...
    FC- 45 drops= 22.5 FC
    CC- 1 drop= .5CC
    TC- 30
    TA- 21 drops= 210
    CH- 48 drops= 480
    CYA= 51
    Pool is blue, getting clear but kinda cloudy.......... Where should I go from here? The pump has been running 24/7
    Thanks for everyones help
    May 2013
    Longview Tx
    21
    also PH around 7.3..............
    Richard320's Avatar
    Jan 2010
    18,967
    Give it another day above 16 FC and if it stalls, report back for the next suggestion.
    May 2013
    Longview Tx
    21
    Should I continue to run pump 24/7?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Yes, run the pump/filter 24x7 untill done shocking.
    Add enough chlorine to bring FC up to shock level (or a little higher) With CYA at 50, you shock level is closer to 20ppm
    Repeat as frequently as practical, but not more than once per hour, and not less than twice a day, until:
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
  20. Back To Top    #20
    Apr 2012
    SW Ohio
    456
    Your readings are confusing .....tc=fc+cc so 22.5+.5 is 23 not 30?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
