Thread: Diverter valve help
    Guest
    Diverter valve help
    Does anyone know what type(brand/model) theses valves are? I would like to replace the inside "guts", but not sure if it is even possible... Thanks
    38,475
    Re: Diverter valve help
    Welcome to TFP!!!
    Are you in Australia? All the websites I see similar valves are down under.
    Try searching for "FPI 3-way valve"
    Guest
    No I am in Florida pool was built in the 90s
    Guest
    I was wondering if I could replace the valves with another brand, but keep the housing so I do not have to make any plumbing cuts... Since there are 8 screws, will another 8 screw vavle such as a pentair or jandy fit inside? Thanks for the help... These fpi valve are very hard to get parts for
    38,475
    Parts between brands are not compatible with each other.
